Axle & Front Fork Question
Old Feb 8, 2004 | 10:07 PM
FredoSP's Avatar
Default Axle & Front Fork Question
Hey guys, I got a 00 Si - B16A2 (just for ref).
I recently installed a set of Gator Stage 2 axles. This might seem dumb but its been bothering me. When we installed the axle, obviously we had to move the fork. When it was time to put everything together, I noticed after the fact that we installed the bolt and nut backwards.
It should be like this/direction, with the nut in the rear
We did it like this with the nut in the front
My question is, does it really matter which way the bolt goes in?
Other pics so you get an idea.
Old Feb 8, 2004 | 10:12 PM
Hoosier Daddy's Avatar
Default Re: Axle & Front Fork Question (FredoSP)
Fred, you lazy ****. Just take the 5 minutes to reverse it! You've done everything else right so far.
Old Feb 8, 2004 | 11:30 PM
mmuller's Avatar
Mad Scientist
Default Re: Axle & Front Fork Question (Hoosier Daddy)
I really dont think there is a difference
Old Feb 9, 2004 | 07:57 AM
tilt's Avatar
the only difference i can forsee is the threads being exposed to the elements head on, like water (as opposed to it being on the backside of the control arm). im no expert but prob nothing to be worried about.
Old Feb 9, 2004 | 08:02 AM
B18C2_sedan's Avatar
On aircraft all bolts face to the rear. Wind being the main factor. In your case you have nothing to worry about.
Old Feb 9, 2004 | 12:35 PM
MightyMouseTech's Avatar
Default Re: Axle & Front Fork Question (B18C2_sedan)
When I see a bolt facing that way on a customers car, I know somebody who doesn't know Hondas very well has worked on it. It honestly does not matter that much, but all Hondas come from the factory with the bolt the other way, and most tech's I know will make sure to put it back the right way. It also makes is easier to put your gun on the head of the bolt to turn it while slidding it out. (Just make sure you don't use a gun on the bolt head to loosen or tighten it )
Although, looking at the bushing, it doesn't look like you put the lower arm at ride height before torquing down the nut. So when you fix this, you can fix the direction of the bolt.
panda teggy
Sep 9, 2011 01:09 PM
shadohconspiracy
Nov 3, 2007 02:22 PM
BANNED_ID
Jun 16, 2005 06:27 PM
gok
Mar 10, 2005 02:56 PM
FredoSP
Feb 8, 2004 11:04 PM
