Camber trouble
Old Feb 8, 2004 | 04:19 PM
IgotV-tec!'s Avatar
Default Camber trouble
Ok , i got the Tein basic damper kit for my 01' Acura TL and the front drop is 3.5 and the back is 2.7 and now i need a damper kit but dont know what to get. I need to find somethin under $200 for the front.Also , do you guys think i really need it for the back? i heard i could just put washers in the back and it'll work the same but its kinda ghetto. Please let me know
Old Feb 8, 2004 | 05:12 PM
bryant's Avatar
Default Re: Camber trouble (IgotV-tec!)
Please do a search first. Either here or on google you could find many different thigs.
I will even give you a few links to get things started:
http://www.google.com
https://honda-tech.com/zerosearch
http://www.spcperformance.com/
Old Feb 8, 2004 | 06:20 PM
IgotV-tec!'s Avatar
Default Re: Camber trouble (Bryant)
well what do you recomend?
Old Feb 8, 2004 | 06:27 PM
ultimatehonda's Avatar
Find out what companies make camber kits for your car. Also find out how the suspension is in the back. The washer trick works on some cars but not all. The washer trick shims the upper rear control arm from the frame so it gives you more postive camber. I would reserch those 2 things then find out what other people are doing with there tl's and what they needed to do. Maybe go get a alignment now and see how off the specs are.
Old Feb 9, 2004 | 12:51 PM
IgotV-tec!'s Avatar
Default Re: Camber trouble (ultimatehonda)
Well so far i have found about 3 camber kits for my car and one of them is by Eibach. So far i think the Eibach kit is the best and its -1.5 to +3.0 degrees but i dont know if thats enough because my drop in the front is 3.5 inches.The kit costs $220 for the front and $160 for the back. What do you think?
EM2_touge
Honda Civic (2001 - 2005)
Apr 19, 2009 07:47 PM
brjhnson
Nov 19, 2006 02:42 PM
SLiCkNiCk
Honda Civic (2006 - 2015)
10
Aug 9, 2006 03:21 PM
Dropped90Integra
Suspension & Brakes
Apr 28, 2005 10:18 AM
Brewer
Feb 5, 2002 01:19 PM
