axel question
Old Feb 25, 2003 | 02:58 PM
wanttorace's Avatar
Default axel question
does it matter if the car has abs for the axles caz we put 92 cx axles on a 94 civic with abs and the cx didnt have abs
Old Feb 25, 2003 | 02:59 PM
Kataku2K3's Avatar
Default Re: axel question (jjd493925)
You'll be fine.. It doesn't really matter... They just have the ABS splines on them... Latez
Old Feb 25, 2003 | 03:00 PM
wanttorace's Avatar
Default Re: axel question (Kataku2K3)
because we put a cluch on and it worked fine but than the car just started reving
and there is no power going to the wheels
Old Feb 25, 2003 | 03:09 PM
e36s52's Avatar
sounds like a problem with the clutch install...
Old Feb 25, 2003 | 03:49 PM
Kataku2K3's Avatar
Default Re: axel question (e36s52)
Yea I would first check the clutch then if it all checks out good maybe there is something wrong with the diff... Make sure you have the axles plugged all the way into the diff.... If your clutch checks out all good then go over the things that I just said... Good Luck
Old Feb 25, 2003 | 04:17 PM
Colin's Avatar
abs and non-abs axles are interchangable....they are the same size, design, construction..... The only difference is that the abs axles have a pickup on them for the abs system to read. If you put non abs axles in an abs car the system won't register the pickup and the abs won't work....thats the only difference.
I'd check to make sure your axles are still together before assuming its a clutch problem. Checking to see if its the clutch is much harder than checking the axles.
Recently a friend of mine did a 5spd swap, he used rebuilt axles from some local parts store. After a day of driving the car wouldn't go anymore. It would rev up, but wouldn't move. he assumed it was a clutch problem too. However after further inspection revealed that the passenger side axle shaft had come out of the outter joint, and the outer joint had seized.
As you know the differential in our cars puts power to the wheel w/ the least resistance (the wheel thats spinning). Since his axle was no longer connected to the wheel it had very little resistance on it. So, the tranny sent all the power to that one axle, it just spun around and around but since it wasn't connected to the wheel, the car didn't move anymore.
good luck.
Old Feb 25, 2003 | 06:47 PM
wanttorace's Avatar
Default Re: axel question (91IntegGS)
well the drivers side axel had came out and i put the axle back in and drove the car and the abs light came on in the guage cluster and the same thing happened it would go anywhere
so im assuiming by using these axles that its the problem caz the axles he had before worked and now these wont the cluch worked properly when driving it when the axle was put back in so any fedback would be great thanks
justin
Old Feb 26, 2003 | 10:13 AM
GM2000ITR's Avatar
New User
If your car has ABS sensors (control module,etc.), then you must use ABS axles! Otherwise the axles with no ABS splines cannot be registered by the sensors.
Old Feb 26, 2003 | 10:19 AM
slomofo's Avatar
GDD Member
Default Re: axel question (GM2000ITR)
It's a good idea to get a hammer and a screw driver and tap out the ABS spline if you don't have ABS. Sometimes the splines on non-ABS cars make a noise because they are rubbing against your suspension and sometimes your axles will not go as far into the hub as they should. I change axles all day, every day, I always have to tap out the ABS spline on people's cars that don't have ABS.
Old Feb 26, 2003 | 10:34 AM
wanttorace's Avatar
Default Re: axel question (slomofo)
ok caz when i was under the car i pushed the axlel all the wayinto the sline and it didnt click it just went in and i could pull it out with out any resistance so im geting new axles
Old Feb 26, 2003 | 02:01 PM
integra6650's Avatar
to my knowledge it shouldnt click but it should definately be hard to pull out
Old Feb 26, 2003 | 05:31 PM
wanttorace's Avatar
Default Re: axel question (integra6650)
looked carefully at the axles and the ring at the end of the spindle wasent there so i wasent locking up
DARIUSZ - DNPhoto
Transmission & Drivetrain
Aug 22, 2009 01:06 PM
OOOtony
Mar 4, 2009 06:38 AM
shortycm17
Dec 26, 2007 03:31 PM
charjacq
Mar 2, 2003 09:21 AM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
