Autometer oil pressure sender question....
Old Mar 31, 2005 | 09:51 AM
C M S's Avatar
Default Autometer oil pressure sender question....
How safe would it be to directly mount the sender(for electric oil pressure gauge) to the location on the back of the block(H22a)? Just until I can find the right stainless line/fittings to mount the sender on the firewall...
Old Mar 31, 2005 | 10:34 AM
tgreaves's Avatar
Default Re: Autometer oil pressure sender question.... (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote"> How safe would it be to directly mount the sender(for electric oil pressure gauge) to the location on the back of the block(H22a)? Just until I can find the right stainless line/fittings to mount the sender on the firewall...</TD></TR></TABLE>
Not too safe at all.. Mainly because the sending unit and the block have different threads in them..
Also because the sending unit is way too heavy to just hang out of the block like that..
Old Mar 31, 2005 | 10:55 AM
C M S's Avatar
Default Re: Autometer oil pressure sender question.... (tgreaves)
Anyone know what(fittings) I need to do this properly?
Old Mar 31, 2005 | 11:08 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know what(fittings) I need to do this properly?</TD></TR></TABLE>
You need to put a 1/8" bspt - 1/8" npt adapter in there.. I would just get the adapter and run a line up to a oil block.. In the oil block you can put your autometer oil pressure sensor..
PM Stan(flamenco-t) and he can get you all setup with the fittings you need..
Old Mar 31, 2005 | 11:18 AM
C M S's Avatar
what do u mean by oil block?
Old Mar 31, 2005 | 11:24 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean by oil block?</TD></TR></TABLE>
A junction for oil to flow through.. Kinda like a vacuum manifold except for oil.. Let me see if I can find a pic for you..
Old Mar 31, 2005 | 11:26 AM
tgreaves's Avatar
Look here..
https://honda-tech.com/zerothread?id=862213
Old Mar 31, 2005 | 12:37 PM
C M S's Avatar
thanks...
Old Mar 31, 2005 | 05:19 PM
PrettyLude's Avatar
http://tunertoys.com/
beaterman
Aug 18, 2008 07:49 PM
Maxcapacity
May 22, 2008 06:04 PM
Maxcapacity
May 22, 2008 05:31 PM
groundzerocivic
Feb 5, 2008 04:16 PM
highboostb18c1
Aug 16, 2004 04:17 AM
