autometer air/fuel guage help!!!
Old Oct 28, 2002 | 08:30 PM
prjctCIVIC's Avatar
Default autometer air/fuel guage help!!!
im installing a autometer air/fuel guage in my 92 h22 civic and want to hook it up to the ecu not the o2 sensor itself, but just want to know exactly what pin do i need to wire the signal wire to?? i was told it to be d14 but just need to make sure, also what would be a good power source and ground for the guage?? thanks
Old Oct 29, 2002 | 08:50 AM
prjctCIVIC's Avatar
Default Re: autometer air/fuel guage help!!! (prjctCIVIC)
nobody knows where the signal wire for the guage goes on the ecu???
Old Oct 29, 2002 | 09:04 PM
jdmsol's Avatar
Well I know that on my ecu it was D14, but I've got a 93 D16Z6 so I'm not sure your ecu will be the same. Sorry I can't help more. Good Luck.
Old Oct 29, 2002 | 09:11 PM
Firedrake's Avatar
Default Re: autometer air/fuel guage help!!! (jdmsol)
If you're using an OBD1 prelude ECU (P13) in your swap, you want to wire the purple wire off the gauge to D14 like said above......it should be a solid white wire....
If it's OBD2, then it's pin D7
Brian
Old Oct 30, 2002 | 11:59 AM
PnX-R's Avatar
Hmm.. Just wanted to throw this in.. But doesn't the O2 Sensor mesaure resistance.?.. And by through a load in parallel or series it affects the resistance in that circuit. Which in turn gives the ECU a bogus reading...
Correct me if I'm wrong....
Old Oct 30, 2002 | 12:17 PM
jdmsol's Avatar
Default Re: autometer air/fuel guage help!!! (PnX-R)
Yeah, I think that might be right. I never even thought about that, thanks for the advice.
Old Nov 12, 2002 | 08:04 AM
CalvitoSol's Avatar
so, does this mean it's bad to tap off the ecu?
Old Nov 12, 2002 | 08:31 AM
jdmsol's Avatar
Default Re: autometer air/fuel guage help!!! (theory48)
Let's just say, hmmmm.....sometimes inaccurate.
Old Nov 12, 2002 | 08:57 AM
zCivic's Avatar
From what I've also heard bad idea to tap off ECU. I was gonna do that and my friend strongly suggested about 6inches from the O2 sensor.
Old Nov 12, 2002 | 03:15 PM
Kataku2K3's Avatar
Default Re: autometer air/fuel guage help!!! (zCivic)
It really doesn't make a difference... The hotter an oxyen sensor is the more voltage it generates.... It really has nothing to do with resistance... I personally like to tap directly off the ECU... Not only does it look cleaner, but then if you ever have to pull the motor, you're not goin to have to unsolder the wires...
Old Nov 13, 2002 | 07:52 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: autometer air/fuel guage help!!! (JDMspecEG6)
Correct.
O2 sensor is a voltage generator.
The ecu and autometer A/F are nothing more than voltmeters.
Old Nov 13, 2002 | 07:55 AM
jdmsol's Avatar
Default Re: autometer air/fuel guage help!!! (Mista Bone)
Okay, you are the most reliable source that I know of on here, so this finally settles this issue. Thanks.
hi mom
Jan 4, 2005 10:39 AM
vtecb20coupe
Oct 6, 2004 05:02 PM
riddickone
Nov 26, 2003 10:24 AM
r30slick
Jun 19, 2002 08:04 PM
