automatic conversion to manual
Old Jul 4, 2002 | 03:54 PM
Ludeboi's Avatar
Default automatic conversion to manual
i have 5th gen lude auto that i do not want to sell, i onlee have 31k on it and its a 98, i was wondering what would happen if i bought a manual tanny from a junk yard and do a conversion, if any problems will occur, and in the long run, also what parts do i need to part out from the lude from the wrecked one to do this? do i need the ecu also? thanks.
Old Jul 4, 2002 | 09:24 PM
millertyme's Avatar
Default Re: automatic conversion to manual (Ludeboi)
hey dude i have a 4th gen lude i wanna do the same thing, have u found ne info on it?
Old Jul 4, 2002 | 09:50 PM
Koori's Avatar
Default Re: automatic conversion to manual (millertyme)
This kinda thing comes up all the time. Okay, it can be done. Can it be done cheaply? Maybe. It's been a while for me to look at a gauge cluster from a prelude but it might still show the whole Automatic pattern lit up. Before I go any further, is it a cable tranny or hydraulic? You will need an ECU cuz the ECU determines shift points in an Auto. Might have to get a different sized brake pedal pad also.. A Clutch might not fit in the current slot next to the dead pedal. I'd imagine get anything and everything tranny related outta the wrecked on... I haven't seen any long term problems with this conversion. Without knowing which tranny, that's all I can say for right now..
[Modified by Hadji, 1:53 AM 7/5/2002]
[Modified by Hadji, 1:54 AM 7/5/2002]
Old Jul 5, 2002 | 08:04 AM
Ludeboi's Avatar
Default Re: automatic conversion to manual (Hadji)
wats the differece between cable and hydrolic, and how would i know?
Old Jul 5, 2002 | 11:47 AM
Koori's Avatar
You'll need the transmission mounts, rear axle, ECU, Shift Linkage, Pedals, gearbox and for safe measure get a helms guide.. Those things are the ****. Anything else, just let me know.
Since it is a wrecked stock lude, I'm sure that it's a hydro tranny.
[Modified by Hadji, 3:47 PM 7/5/2002]
Old Jul 5, 2002 | 03:53 PM
Ludeboi's Avatar
thanks alot, im going to go take a look at the wrecked car next week, but im still courious on what the difference between cable and hydro?
Old Jul 5, 2002 | 11:02 PM
Koori's Avatar
Basically, it's all in what shifts the gears. A cable tranny relies on, well, cables to get from gear a to gear b. A hydro uses some sort of pressure/pump to get a gear where it needs to go.
Old Jul 5, 2002 | 11:43 PM
Spyder500's Avatar
if you have a 98 Lude
and u pull it out of a wrecked 97+ Lude for sure it'll fit!!!!
cause in 97 they made a new Lude with the new body style and motor.
and that 97+ is a Hydro Tranny
as for the older ludes.
93-96
i think they started that gen lude in 93 or 94
any way those suckers as well are Hydro Tranny.
Hydro trannys are better than cable tranny
it shifts smooter and it can be abused more with harder grinding shifts.
also as well as the different gear ratios, and etc..
[Modified by Spyder500, 8:44 AM 7/6/2002]
Old Jul 6, 2002 | 09:50 AM
Ludeboi's Avatar
thanks
Old Jan 31, 2003 | 01:24 PM
PartTimeRiceR's Avatar
Ok even with all the parts needed, are there any modding required? Like shift linkage, the hole where the shifter comes up, any cutting needed?
Old Jan 31, 2003 | 01:44 PM
lunarcry's Avatar
Helms Manual (VERY IMPORTANT) Helm Inc
Transmissions Assembly (97+)
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
Auto ECU or 5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster (optional)
Cotter Pins (assorted sizes)
Assorted Nuts and Bolts
*this parts should come with the transmission but check just in case.
(all this,is what you will need good luck )
bpl0807
Nov 15, 2011 04:11 PM
DAGAME
Sep 8, 2007 05:47 AM
blackludevtec
Mar 29, 2007 03:10 PM
isotopesope
Oct 9, 2002 11:02 AM
