ATS final drive, strange sound
Old Dec 5, 2005 | 08:37 AM
No_Fear's Avatar
Default ATS final drive, strange sound
Hello
after installed a final drive 4.9 for Bseries ,i hear a strange sound from the gearbox even when i have no gear and the car goes 50km i hear it.is it normal that? anything i can do for it ?
Old Dec 5, 2005 | 09:34 AM
KooK's Avatar
Mustang Sally
Default Re: ATS final drive, strange sound (No_Fear)
Hello
Ehhh, did you install it or did you have a shop install it?
Sounds like it isn't shimmed properly. If you had a shop do it, take it back to the shop and tell them they're idiots and to fix it. Maybe leave out the part where I called them an idiot.
Off-Topic : I'm thinking english isn't your first language. You're not bad at it, but it just sounds like it from how you type.
By the way guys, if I'm wrong than please correct me here, because I'm going off what I know on my Mustang here, but I do know there are some gears and Ratios out there that do make noise, typically it isn't normal though.
Old Dec 5, 2005 | 10:25 AM
No_Fear's Avatar
Default Re: ATS final drive, strange sound (KooK)
installed in a shop and installed corectly,its not their first time.anyone with ATS can hear that noise also? can it be fixed?
yeap english is not my language.
Old Dec 5, 2005 | 11:30 AM
_BEN_'s Avatar
I helped install an ats gear set once.
And yes we had to take the transmission out because it needs to be reshimmed. We assumed that the stock shimming would be ok but it was not.
After we fixed it the gears were noticably louder before. It is because they are cut differently than the oem ones.
The edge of the reverse gear that was just barely touching one of the others.
Old Dec 6, 2005 | 06:00 AM
No_Fear's Avatar
thanks for replys
ATS is the best mode ,but i was disapointed a little cause of that noise
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
magicmike23
Aug 18, 2007 05:28 PM
a2_DC5
Sep 9, 2006 05:44 PM
94ls
Sep 2, 2004 05:11 AM
cvstrat
Oct 27, 2003 10:01 AM
