Assembling From Bare Block
Old Jan 11, 2009 | 07:36 PM
rdssk8rcs1's Avatar
Default Assembling From Bare Block
I am about to assemble my block from bare crank. I have rebuilt it before but never had the crank out. I was wondering what sort of special things do I need to watch for or what special things do I need that I wouldn't have used before? Any sealants or adheasives. I thank you ahead of time for any input.
Old Jan 12, 2009 | 06:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Assembling From Bare Block
well I recently read through a VERY thorough LS/CR-VTEC engine assembly how-to, from beginning to end, from bare crank to fully assembled. But I can't seem to find it at the moment. I don't think I posted in it so it's not in my subscribed topics list.
It should help you out alot if I can find it, even though you may or may not be doing an LS/VTEC build. Most of the procedures shown would still apply to the assembly of most engines.
Old Jan 12, 2009 | 10:11 AM
rdssk8rcs1's Avatar
Yeah. That sounds like it would help a lot. Please post up if you are able to find it. In the meantime I will do some searching myself for it. Thanks again
Old Jan 12, 2009 | 10:17 AM
Combustion Contraption's Avatar
Just buy a basic engine building book. Something like this
http://www.amazon.com/Engine-Bluepri...1787779&sr=8-4
And then get a HONDA service manual for the engine you are working on with all the TQ specs you and proper TQ'ing sequences you will need.
Old Jan 12, 2009 | 03:13 PM
92civicx's Avatar
helms manuel is awesome
Old Jan 12, 2009 | 03:52 PM
standbackimapro's Avatar
Use engine assembly lube on the crank bearings and rod bearings, torque everything right
Old Jan 12, 2009 | 11:27 PM
KillerBee18's Avatar
Here you go with you tube videos and all...
http://www.evans-tuning.com/videotec...ine_build.html
Old Jan 14, 2009 | 10:00 AM
Community Builder
Ah ha!! Here it is in the All Motor forum. I only looked through the guy's initial posts, but there are hundreds more to read through.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
USDM-EK4*
Nov 24, 2007 07:10 PM
hp80
Nov 10, 2007 11:46 AM
ctr-ek
Nov 5, 2007 06:30 AM
dornon13
Jul 6, 2004 05:54 PM
