Arp rod bolts Torque
Old Jan 23, 2012 | 04:19 AM
turn it up's Avatar
Default Arp rod bolts Torque
Looking for the torque setting for a b16a arp rod bolts.
I have searched and found 50 ft-lbs.(also found 43 ft-lbs and 46 ft-lbs)
Standard bolts are 30 ft-lbs seems like a fair jump so just double checking
Thanks Eugene
Old Jan 23, 2012 | 05:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Arp rod bolts Torque
Why don't you go to ARPs website where all that information is? Did you not get the spec sheet in your package?
Old Jan 23, 2012 | 06:03 AM
turn it up's Avatar
As you can see i have researshed it and gone to the website it is saying 50 .
Just making sure here cause it seems a little high is all better safe than sorry.
Old Jan 23, 2012 | 06:31 AM
rich7777's Avatar
Email them, there probably 43 ftlb. Remember there not a simple 'plug and play' item. BIG ENDS MUST BE RESIZED !
Old May 22, 2012 | 11:22 AM
Steeve_Civic's Avatar
Have you checked with ARP about the 50ft/lbs?
Part number is 208-6003 ?
Thks
Old May 23, 2012 | 10:43 AM
50ft/lbs, is not too much?
Old May 23, 2012 | 10:52 AM
doood's Avatar
been there done that
seriously it's on their damn site. i found it in 2 seconds.
Old May 23, 2012 | 10:53 AM
JW racing's Avatar
The paper on the box from the last B series I did said 45. Use the moly lube for that, and have the big end of the rod bore blueprinted to spec after the bolts have been pressed in.
Old May 23, 2012 | 09:56 PM
Yes I know here is the link,
http://arpinstructions.com/instructions/208-6401.pdf
but 50 is much more that OEM
Old May 24, 2012 | 08:04 AM
JW racing's Avatar
That is because the bolt is much better and stronger and has a different stretch amount when torqued than an oem bolt.
Old May 26, 2012 | 12:52 PM
EG1834's Avatar
Make sure you're looking up the correct part number. I had a buddy torque his 3/8" bolts to the 7/16" bolts torque value.
Old May 26, 2012 | 04:45 PM
1994turbocivic's Avatar
i am currently having issues with same matter. i have b16 rods, re-sized crank ends w/ arp rod bolts...
at 40ft lbs, which arp states in instructions, my rods can move side to side???? idk if i should crank it up to higher torque
hatchyboy89
Aug 6, 2010 08:11 AM
leem23vtec
Jul 18, 2010 06:58 PM
H22coupe
Apr 30, 2004 05:24 PM
b20ek
Jun 15, 2003 07:02 PM
