arp rod bolts and machining???
Old Apr 28, 2011 | 11:21 AM
lriver0001's Avatar
Default arp rod bolts and machining???
What's up ht I have a set of arp rod bolts that I plan on using on my ls rods for a lsvtec build and my question is: must I have the big end of the rod honed? And if so would I use an oversized rod bearings?
Old Apr 29, 2011 | 07:10 AM
mik101's Avatar
Default Re: arp rod bolts and machining???
You should have it checked (and probably resized) but you will not have to use oversize bearings unless your clearances on the rod journals of the crank require it.
(They should be able to make it round again without oversizing the journal of the rod)
So as long as your crank measures good you should be okay.
itr_henrik
14
May 25, 2007 02:08 AM
REEMB18C1
Jul 21, 2005 04:09 PM
B18EG6
Jun 30, 2004 04:15 PM
inFamousOneSix
Jul 9, 2003 12:29 AM
2020ls
Aug 20, 2002 03:38 PM
