ARP head studs without taking off the head?
Old Sep 20, 2009 | 12:42 PM
red civic standard's Avatar
Default ARP head studs without taking off the head?
Has anyone done this? Did you experience problems later?
If I do decide to go this route, should I remove all the stock ones two at a time and replace with ARP torqued to spec or just remove all the OE ones and then use typical ARP tightening process?
Old Sep 20, 2009 | 12:52 PM
turbojdmhatch's Avatar
Default Re: ARP head studs without taking off the head?
i know a guy who does this with the evo's he builds...he does them one at a time...i plan on doing this with my d series soon...i talked to a guy a lil while ago and he did it this way also and he said he has not had a problem with it
Old Sep 20, 2009 | 01:00 PM
Bullettdsm's Avatar
Its been done many times on our cars. I've done it, no problem with headgasket etc. One at a time and don't forget to lube the stud.
MB
Old Sep 21, 2009 | 09:00 AM
anyone else with similar success stories?
Old Sep 22, 2009 | 10:35 AM
mouab18c1's Avatar
it's like halfassing homework
Old Sep 22, 2009 | 11:50 AM
not really...as long as u do it correctly its fine...you dont have to take the head off just to put head studs in...hell a lot of V8 guys put the heads on then put the studs in
Old Sep 23, 2009 | 11:33 AM
unusual71's Avatar
if your going to all this trouble why not replace the headgasket? seems like a waste of a good opportunity. I guess if your cheap ok, but then why are you replacing the bolts with studs in the first place?
Old Sep 23, 2009 | 06:28 PM
mouab18c1's Avatar
thats what i was thinking...might as well change everything right?
Old Oct 3, 2009 | 11:53 AM
909Dc2Racer's Avatar
there's a reason that you take the head completely off you might want to look at pistons and walls and might as well replace the head gasket
Old Oct 3, 2009 | 11:54 AM
"don't go cheap on the things that matter"
( o )( o )
Jun 2, 2012 04:13 AM
D16Y8-JDMYO
May 24, 2007 10:21 AM
LSVtechnologytur...
Mar 31, 2005 05:19 AM
tuan...
Sep 22, 2004 09:33 AM
LsTurbo91
Apr 5, 2002 08:08 PM
