Anyway to bypass ECU for reverse lights?
Old May 20, 2016 | 04:34 AM
GRN-BNDT's Avatar
Default Anyway to bypass ECU for reverse lights?
I know this is a weird question and it's not even for my car, but my friend is missing some harness for his reverse lights on his Nissan 240sx. Would there be anyway of wiring a relay in for the reverse lights? Does the reverse light sensor put out any amount of power to be able to work as a signal wire for a relay? Or is there some other way of doing it?
Old May 20, 2016 | 05:00 AM
StokelesS_g2's Avatar
Default Re: Anyway to bypass ECU for reverse lights?
WTH, Bypass ECU? A 240 Question?
Is this to pass inspection or something?
It's a just a light, get a switch.
Old May 20, 2016 | 08:59 AM
GRN-BNDT's Avatar
Yeah, exactly, it's to pass inspection. I know a switch would turn them on, but would that pass inspection? We were trying to keep it to where they would turn on themselves when you put it in reverse.
Old May 20, 2016 | 10:16 AM
fcm's Avatar
fcm
Old Fart
Not knowing how the revers lights work on a 240 I am just guessing but I do not think the ECU has anything to do with the rev. lights, my guess is it will be like most cars a switch on the transmission that power runs to and out of, [when in rev.] to the reverse lights.
What year is the car? 94
Old May 20, 2016 | 10:23 AM
fcm's Avatar
fcm
Old Fart
Looks like switch is located on the tranny accessed from under the car, there should be 2 switches/sensors on the tranny, the one towards the rear is the rev. switch. 94
Old May 20, 2016 | 12:06 PM
GRN-BNDT's Avatar
It's an S13. 89 or 90. I don't really know how the lights work either, I know it has two wires coming out of it, just like my Sol reverse sensor, so I figured it would work the same. Is one wire an input power and the other is an output power and when the trans is put in reverse it completes the circuit?
Old May 20, 2016 | 12:08 PM
GRN-BNDT's Avatar
And when I said ECU, I really just meant the factory wiring harness type deal. It apparently runs into the fuse box and then goes out to the reverse lights, so I'm assuming I'll also need an inline fuse.
Old May 20, 2016 | 01:53 PM
v4lu3s's Avatar
RTFM
have you guys looked at a wiring diagram for the car? should be pretty clear how it is set up and usually 2 wires are not hard to run if you need them...
Old May 28, 2016 | 11:44 AM
I'm not sure about VA inspection laws.
But in NC, My buddy bought a parts car civic, swapped in a H22, wired a horn switch and reverse back up light switch, and he passed inspection down here.
I guess as long as you can get it to work somehow, LOL.
JoseCuervo
Lighting
Feb 28, 2012 04:38 PM
ttk3
Lighting
Jan 14, 2008 04:34 AM
stupidwhitecat
Nov 5, 2005 04:26 AM
HondaKPX
Jul 25, 2005 10:44 PM
