Anyone know a good method of taking these off..?
Old Nov 2, 2003 | 07:56 PM
Gonzo_SiR's Avatar
Default Anyone know a good method of taking these off..?
whats a good easy way to take these O2 sensors off the manifold..?
Old Nov 2, 2003 | 08:05 PM
gsrinstyle's Avatar
Default Re: Anyone know a good method of taking these off..? (Gonzo_SiR)
put it on a vice and use a big wrench to take them out. i believe, dont quote me, they are 22mm wrench. dont try using adjustable wrench cuz it will strip. if it still doesnt come out, heat it up a little. heat around the sensor, not the sensor itself. good luck
Old Nov 2, 2003 | 08:08 PM
Gonzo_SiR's Avatar
Default Re: Anyone know a good method of taking these off..? (gsrinstyle)
but how do you get the damn wrench on therein the first place.... it's a really tight fit... and due to the wires...I cant get a socket in there either....ahhh!
Old Nov 2, 2003 | 08:13 PM
sledgehammer's Avatar
theres a special socket you can buy specifically for taking off o2 sensors, it has a slit up the side for the wires to go.
Mike
Old Nov 2, 2003 | 08:32 PM
Gonzo_SiR's Avatar
Default Re: Anyone know a good method of taking these off..? (sledgehammer)
cool... thats the kind of answer i was looking for... thanks bro.
Old Nov 2, 2003 | 08:43 PM
maxxdout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer &raquo;</TD></TR><TR><TD CLASS="quote">theres a special socket you can buy specifically for taking off o2 sensors, it has a slit up the side for the wires to go.
Mike</TD></TR></TABLE>
This works in some cases. however, i have an O2 sensor tool from Mac tool. I dont have the part #, but its almost like a crowsfoot wrench. It is a lifesaver. It has a square 3/8 drive hole on one end of it. I hope this helps.
PS: what engine is that off of? I did a swap this past summer for a guy and he brought me a b16 that was equipted with this stock manifold and i had never seen it. Im sure its something common just wasnt familar with what car that came off of. The engine was mated to a cable clutch.
Hope the above mentioned information reguarding the O2 sensor tool helps.
Old Nov 2, 2003 | 09:23 PM
Gonzo_SiR's Avatar
Default Re: Anyone know a good method of taking these off..? (maxxdout)
B16A 1991 CRX SiR engine
Ess0n23
Aug 10, 2007 10:01 PM
sky9
Dec 6, 2006 10:28 AM
SuperSi
Nov 1, 2005 07:43 PM
icon_race_eg
14
May 5, 2004 05:49 PM
b18bvudoo
Jan 6, 2002 10:22 AM
