anyone ever solved honda's infamous idle problem??
you guys know what i'm talking about. after a few serious engine mods, you fire up the engine and after it warms up... the idle goes up and down.. up and down.. up and down.. up and down. wtf is the deal here? i know someone out there has figured this one out... time to step forward.
standalone
I've heard everything from new map sensors to EACVs and temp senders. I dont know how to fix it. I just hope the standalone will correct it.
check these few things to make sure everything is running correctly IACV, PCV valve, FITV, low on coolant, ECT sensor, and the one that has always cost me the most trouble is the TPS. It's kinda good cuz it's easy to fix if it's the problem. Make sure the TPS signal wire has 0.5 volts coming out of it at idle and about 4.5-5.0 at WOT. If it reads 0.5 or above it's most likely something else. If not then slot the two screws that hold it in and back them out a bit till you can rotate the sensor until it reads 0.5 volts. Have fun!
FITV (fast idle thermo valvle) - unbolt the 3 bolts that connect the the underside of hte throttlebody, the whole piece comes off. then unbolt the 2 10mm botls that hold the metal plate. inside, there is a plastic piece inside. just get a flat head and screw it back in.
EACV - just replace with a known good one
TPS - not really usually the case ubt probably needs adjusting.
The 3 majors things i've seen that cause it are these (usually fixed in this order)
so for the fast idle valve fix you just block off the opening?
here's an interesting tid bit of info regarding the problem on my car. when i disconnect the connection from the wiring harness to the IAC valve (aka EAVC), the problem instantly stops. in the past i have put a thin piece of metal in between the valve and the intake manifold.. which solves the problem, but i have to give it throttle when the car is warming up or the engine will die. what i would really like to do is fix whatever is wrong so it idles like it did fresh off the showroom floor.
mistahmac
10
Aug 29, 2007 05:41 AM
mikeunreal2
Mar 29, 2006 09:27 PM
