Any one ever have problems with jun cams on a h22
Old Nov 4, 2003 | 03:09 PM
DxTrix's Avatar
Default Any one ever have problems with jun cams on a h22
Put my cams in with jun springs, rev valves, some titanium retainers and 370cc injectors on my port and polished head but the car will not idle. The car runs so bad that I am debating that this problem is because it needs to be tuned. Any one ever had this experiance or know what to do?
Modified by DxTrix at 12:23 AM 11/5/2003
Old Nov 4, 2003 | 05:15 PM
vteczone's Avatar
Default Re: Any one ever have problems with jun cams on a h22 (DxTrix)
i think may be u need tuning.my friend had everything stocks except for the jun cams,valve n retainers and it ran fine.
Old Nov 4, 2003 | 05:17 PM
Chemicalviper's Avatar
Jun cams even say that the stock idle will be effected because it is more of an agressive cam ( im think of the higher stages ) - You need hondata and tune.
Old Nov 5, 2003 | 07:15 AM
DxTrix's Avatar
Default Re: (Chemicalviper)
That is what I am thinking that it needs to be tuned. I even have engine manigment but I did not want to take a car that has something wrong with it to get tuned just to find out at the dyno that it is more then tuning it needs. Thanks for the input though. By the way I believe the h22 jun cams are stage 3s. VTECZONE did your friend just instal the cams or did he get it tuned and did he have any isues at first.
Old Nov 5, 2003 | 07:35 AM
2point6's Avatar
Default Re: (DxTrix)
what is the valve lash at right now?
Old Nov 5, 2003 | 08:01 AM
DxTrix's Avatar
Default Re: (2point6)
I am not sure what you are referring to can you be more spacific.
Old Nov 5, 2003 | 08:33 AM
2point6's Avatar
If your valve clearances are too tight, the engine will have a hard time keeping idle. Re-check the clearances.
Old Nov 5, 2003 | 08:44 AM
DxTrix's Avatar
They were adjusted about 2 months ago so I dont think they were to tight. This head was on another car and it ran ok but now it is just bad it wont stay on.
Old Nov 5, 2003 | 09:36 AM
topdog's Avatar
readjust your valve lash to the JUN cam spec that is what 2point6 mean and did you degree the cams in...and also JUN only has a stage 1 cam for the h22a...
topy
Old Nov 5, 2003 | 10:00 AM
DxTrix's Avatar
Default Re: (topdog)
I am going to have them re adjusted but what do you degree the cams to. The jun h22 cams I was told is actualy equal to a stage 3.
Old Nov 9, 2003 | 10:01 PM
AMS MIKE's Avatar
Jun cams in an H22. dayammm that **** must bone out. yeah sounds like its a tuning issue and maybe its just telling you its time to go nawz
Old Nov 10, 2003 | 10:03 AM
Boltz's Avatar
Default Re: (ZRD OWNS ME)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZRD OWNS ME &raquo;</TD></TR><TR><TD CLASS="quote">Jun cams in an H22. dayammm that **** must bone out. yeah sounds like its a tuning issue and maybe its just telling you its time to go nawz</TD></TR></TABLE>
hell yea, nothing like spraying an untuned car that already has problems
Old Nov 10, 2003 | 09:01 PM
AMS MIKE's Avatar
Default Re: (FourceFed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourceFed &raquo;</TD></TR><TR><TD CLASS="quote">
hell yea, nothing like spraying an untuned car that already has problems </TD></TR></TABLE>
I sprayed 140 shot on my untuned Type-R. man it was sooo fast and then i heard a kaboom and my rod let go. I still don't know why it happened. I am thinking it was my Jun stage 3 cams I had. They were the problem that my rod let go.
Old Nov 11, 2003 | 06:32 AM
skunk2lude01's Avatar
actually jun only has stage 3 camshafts for h22/
Old Nov 11, 2003 | 06:41 AM
se93's Avatar
Default Re: (skunk2lude01)
I have run into a similar problem when i installed a fully prepped (port/polish/welded chambers and milled .015) with my JUN cams. Idle was lopey and a bit unstable. Before installing this prepped cylinder head, the stock unmodified head and JUN cams gave a good, solid unproblematic idle. With this new cylinder head, i managed to get idle working well with my hondata
Idle now is nice and stable. Love the sound of it now.
If you have the chance to degree in your cams, that would be great. I did not have the opportunity since my mechanic was on a suicide schedule (lots of work) and decided to just set the the camsprockets at 0,0 for the moment.
Hope that helps you a bit.
Old Nov 11, 2003 | 07:02 AM
DxTrix's Avatar
Default Re: (se93)
I have good news and bad news that I found out, there was a posibility that my head was cracked but it turns out its fine and I had 3 bent valves after puting new ones in about 5 months ago. Also turns out the block the head was on before may have the pistons put in wrong that is what is causing my valves to bend. Sucks cause I put a stock head on that block and bent those valves also so thats 2 heads with bent valves that I need to fix.
Old Nov 11, 2003 | 07:04 AM
se93's Avatar
damn! Sorry to hear that. Hopefully you'll get it all right and start enjoying those H22 JUN cams!!! What kind of fuel management are you running?
Old Nov 11, 2003 | 07:13 AM
DxTrix's Avatar
Default Re: (se93)
I was running a reprogramed ecu by ericks racing till I could get it to a dyno. I have a aem ems that was sapose to go on there. Well I hope I get a chance to enjoy them all motor before I go turbo but if not they may go on my turbo motor.
dildo2
55
May 21, 2010 10:22 PM
snowblind7x
Jul 9, 2006 12:36 PM
SpanishRicer
Oct 18, 2004 12:14 PM
ArtilleryRacer
Jun 15, 2003 11:55 AM
se93
Oct 28, 2002 08:12 PM
