Any helpful tips on Skunk IM on 00 Si??
Old Apr 3, 2003 | 01:11 PM
quik2kSi's Avatar
Default Any helpful tips on Skunk IM on 00 Si??
I am about to put on a Skunk IM in my 00 Si as soon as the TB and IM gaskets come...you guys have any helpful tips. I no i have to block the IAT valve on the man. because it is on my intake pipe, but what else?
Old Apr 4, 2003 | 11:00 AM
quik2kSi's Avatar
Default Re: Any helpful tips on Skunk IM on 00 Si?? (quik2kSi)
ttt
Old Apr 4, 2003 | 11:52 AM
WS6Dreams's Avatar
I just installed one on my Si, pretty straight forward install, just have fun with it and enjoy the results. Good luck.
Old Apr 4, 2003 | 12:13 PM
stevel's Avatar
Default Re: Any helpful tips on Skunk IM on 00 Si?? (WS6Dreams)
did you dyno it before/after? Did you get a bigger TB? what size? What do you think of the results. Did you lose any low end because these cars don't have any to begin with. Thanks...I'm thinking of doing it myself.
s
[Modified by stevel, 4:13 PM 4/4/2003]
Old Apr 4, 2003 | 12:19 PM
Katman's Avatar
you can actually use the IAT sensor that's meant for an ITR manifold....you'll just have to extend the wire(s)+plug from your current IAT to the manifold mounted IAT sensor.
I think you *might* need an ITR throttle cable (could be wrong; you could probably reuse your Si coupe TB cable) and for sure you'll need an ITR throttlecable bracket for the ITR manifold.
other than that..it should be a straight bolt n' play application.
Old Apr 5, 2003 | 07:53 AM
quik2kSi's Avatar
Default Re: Any helpful tips on Skunk IM on 00 Si?? (Katman)
or i could use an IAT sensor from an ITR and not wire it up, just put it there to plug the hole.
Old Apr 5, 2003 | 11:52 AM
Katman's Avatar
yes, you can do that too.
What's the deal w/ "" ?
Just givin you a got damn suggestion and you gotta get all " " on me, eh?
WUTEVA!
Old Apr 5, 2003 | 04:10 PM
quik2kSi's Avatar
my bad it wasn't intended 4 you...it's just that i didn't think of pluggin it that way before.
Old Apr 7, 2003 | 09:45 AM
Katman's Avatar
....its all good. I was f'in wid ya
djickabod
Apr 25, 2004 09:01 AM
