Well what do you think could be causeing the leak? Just alittle info Im running a rebuilt D16a6 si with a tdo4 greddy turbo kit. do you think i should junk this motor and go for a swap?
HELP ME SOMEONE PLEASE!!!!
What do you mean oil leaking from the exhaust? Is it coming out of the exhaust as blue smoke or something? How long have you had the turbo, how many miles does the engine have on it, is it stock internals? How much boost are you running. Need details.
are you sure it's oil? because often times, condensation in the exhaust piping and muffler will pick up enough soot and carbon to turn totally black, and looks like oil..
could be bad oil control rings..to much p-w clearence on rebuild..bad turbo oil seals...or maybe even a BAD head gasket leak or valve seals..
umm..i bought the car as is im tryin to get it on the road.. I already know there is a head gasket leak. And somone has already told me that if theres oil leaking from the head gasket they could be linked together. But how? thanks for your help guy!!
there is more of a black greyish smoke comin out ..the motor has been rebuilt but i dont know who and how many miles it was rebuilt at when they rebuilt the motor they messed with the odometer and put 947893 miles ..what i do know is it has forged pistons and port and polished heads.but like i said i can't tell you much about it because i don't know much myself i bought the car as is
change the gasket and go from there...also do a compression test.
