another new problem (coolant system related)
Old Apr 28, 2003 | 10:20 PM
riceboyEFsi's Avatar
Default another new problem (coolant system related)
not sure fan is turning on . I used a thermo. housing from a 92 gsr on my b18 c5 in a 91 si . What i did was spliced the harness from where the original thermo switch wires were and put a clip from another harness which plugged into the 92 gsr thermo housing . Shouldnt doing that work to make the fan turn on automatically? Also the overflow tank is bubbling very violentley . Also noticed the upper rad. hose is VERY soft and flattens out. Im changing the hose in the A.m. Any ideas guys. thanx >>>e
Old Apr 29, 2003 | 06:01 AM
Default Re: another new problem (riceboyEFsi)
any1? , bueller!!!!
Old Apr 29, 2003 | 06:08 AM
10K2HVN's Avatar
even with you fan not turning on it should over heat..i drove with a working fan for at probably a full year or more! temp went up and down but never past half point. Even after a couple of 8000 rpm ragers then sitting in parking lot trafic on a hot summer day it never went past half point!! ..until ( ) my thermostat went bad..got it fixed everything back to normal....
maybe check your thermalstat....
Old Apr 29, 2003 | 10:12 AM
Default Re: another new problem (10K2HVN)
i wired up the fan to ignition and it seems to be working, i cant realy tell cause i keep having alternater problems (shitty aftermarket rebuilds ), Goin on # 3 . Not sure if i need a thermostat or not cause my blower motor took a **** but i dont need heat right now so who cares . I luv spring Ill keep ya guys posted. Thanx >>> e
BlkTegOn18s
Feb 23, 2009 05:15 PM
DarkBB4
Apr 9, 2006 02:55 PM
stealth civic
Jan 13, 2005 09:03 AM
urzaofusn
Jul 8, 2004 05:50 AM
ek9si
Jun 18, 2003 04:42 AM
