anger managment
Old Nov 9, 2003 | 12:14 PM
Audi RS4's Avatar
Lover
Default anger managment
so exactly how many bolts hold a b16 tranny to the motor? I've got seven out right now and can not find anymore is that all of them??
and........ WTF is still holding this tranny to the engine?
i have removed all mounts and i think all the bolts
can i rotate the tranny or is it more of a pull back and forth type of effort.
TIA
Old Nov 9, 2003 | 12:31 PM
JONBLAZE55555's Avatar
Default Re: anger managment (AK1200)
did you take out the starter and soloniod? when i did my clutch job i had the same problem. one of the starter soloniod bolts help hold the trany. at least it does with d series
Old Nov 9, 2003 | 12:36 PM
Audi RS4's Avatar
Lover
Default Re: anger managment (JONBLAZE55555)
i did not remove the starter just the upper mounting bolt for the starter. i will remove the whole damn thing and see if that helps. thanks
Old Nov 9, 2003 | 12:56 PM
Audi RS4's Avatar
Lover
damn the book says the upper bolt but it is actually the lower bolt............grr..
Old Nov 9, 2003 | 04:24 PM
iwhichisme's Avatar
you have to remove the starter in order to remove the tranny. one of the bolts that hold the starter in place, also supports the tranny. Remove the starter, fight with the tranny, and out she will come.
Old Nov 9, 2003 | 05:36 PM
sikcrx80's Avatar
yeah u do have to remove starter and the intake mani braket too.. there is also a shield under tranny flywheel side take it off too.
Old Nov 9, 2003 | 07:01 PM
Audi RS4's Avatar
Lover
Default Re: (sikcrx80)
thanks guys, 8 hours later and it's done finally........
obuhmyuh
Jan 9, 2008 03:55 PM
Ben_si
10
May 3, 2005 08:33 AM
luti
Nov 29, 2004 11:52 AM
SuperDuude
10
Jul 1, 2004 09:24 AM
Unjockable
20
Nov 10, 2003 02:36 PM
