Car will not start! Please help! I tried everything!
Old Nov 6, 2003 | 10:39 AM
incertitude's Avatar
Default Car will not start! Please help! I tried everything!
I'm sure you all have heard of the classic no spark/no start thing with hondas, I have a 96 civic ex. I tried everything! I replaced the distributor, thinking it was the ignitor, I re-soldered the main relay, thinking it was defective. Fuel pump is getting power, same with ecu. All fuses are good. Could it be a ground somewhere? If so, which ones should I check? Please help!! Thanks
Old Nov 6, 2003 | 11:14 AM
b20turbojason's Avatar
Default Re: Car will not start! Please help! I tried everything! (incertitude)
are you getting no spark
Old Nov 6, 2003 | 11:15 AM
thats right.... no spark
Old Nov 6, 2003 | 01:23 PM
jdm civic 2000's Avatar
Default Re: (incertitude)
check them all,theres only 5-6 grounds
-1 from valve cover
-1 from tranny to chassis
-1 from engine harnes bolted to the thermostat housing(the conector is a metal conector with a 10mm bolt atached to it and 2 small black wires connecting
-1 on battery terminal
-1 on main fuse box under hood
-1 on starter
my tranny to chassis ground was loose and my car would not start,then i check my grounds and found out y it didnt start..hope this info helps
Old Nov 6, 2003 | 01:37 PM
infinite's Avatar
i know exactly what your problem is its the ground on the thermastat just take the 10mm bolt out get some sand paper clean the motor part and the wire on both sides real good and then youll be good to go its as easy as that c-ya good luck
Old Nov 7, 2003 | 10:46 AM
I cannot find the ground on the thermostat??? Is there any way I can make a new ground to the thermostat? If so, where should I ground it?
Old Nov 9, 2003 | 06:24 PM
Wilson C.'s Avatar
did you buy everything for the distributor new. If not i would try that first, and make sure you put the spark plug wires back in the right firing order. Make sure it is in time because it could have jumped time also.
Old Nov 9, 2003 | 07:35 PM
bruthaboost's Avatar
If you do not have that piece of the wire harness that is supposed to be grounded at the thermostat not grounded, the car will not start. Look for a little metal tab with a hole in it from your wiring harness around there. Bolt it down to the thermostat. It's a 6 or 8 mm bolt.
HTH
dirrtybirdy
Mar 28, 2010 01:43 PM
jOnW89
10
Jul 15, 2009 02:07 PM
hybridmath
30
Jul 20, 2008 03:38 PM
sirjmj
Jun 21, 2008 09:06 PM
MetalKill
10
Jan 30, 2003 07:42 AM
