aluminized???
Old Feb 11, 2003 | 08:24 PM
arjusmc's Avatar
Default aluminized???
what is the differences between aluminum and aluminzed piping. i need some conectors for my turbo and intercooler welded. will both of these work, or just aluminum, if so anyone know of anywhere that has good deals on the piping?
Old Feb 11, 2003 | 08:49 PM
archmage's Avatar
Default Re: aluminized??? (arjusmc)
wait...aluminized ? or Anodized ? as in.. aluminum oxide ?
I'm confused now
Old Feb 11, 2003 | 08:59 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Aluminum tubing is made out of...aluminum.
aluminized tubing is made primeraly out of mild steel, and aluminized through a chemoelectrical process, similar to galvanzing, where a thin ply of aluminum is transfered by the means of electrolytics.
stan
sorry, my chem knowledge is rusty, that is the best i can remember.
edit, dyslexia ownz me
[Modified by 90crxsi, 10:00 PM 2/11/2003]
Old Feb 12, 2003 | 05:19 AM
JimBlake's Avatar
Default Re: aluminized??? (archmage)
I'm confused now
Aluminized means the pipe, usually steel, is coated with aluminum.
Anodizing can only be done to an aluminum part, it coats it with aluminum oxide.
Old Feb 12, 2003 | 05:31 AM
arjusmc's Avatar
any of you guys welders, can someone tell me if you can use aluminized for tig welding?
Old Feb 12, 2003 | 07:38 AM
Wes V's Avatar
I believe that the prior post about what "aluminizing" is, is incorrect.
As I understand it; aluminum wire is fed through a "chopper" gun that heats it and spits out the small pieces of aluminum. It bonds onto the metal (steel) due to the heat. I've had this done to headers and it's a great surface that will not rust. It also disipates heat real will. The surface is rough in texture and if not painted is a light silver cover.
One interesting problem is if you want to modify the part by welding! (as in installing an O2 bung) If you try going gas welding, the aluminum will spread the heat and the weld will tend to burn through. So, modify the headers prior to coating!!
One problem is that you can't coat the inside surface of a header.
Wes Vann
thegatekeeper14
Welding / Fabrication
18
Apr 19, 2011 07:50 PM
denraweb
Feb 7, 2008 09:35 AM
buda18
Aug 18, 2006 12:06 PM
Blanket Jackson
Apr 6, 2004 05:03 PM
OKSolSi
May 7, 2002 12:08 AM
