alternator obdI to obdII
Old Jan 9, 2003 | 10:20 AM
asianspeed's Avatar
Default alternator obdI to obdII
Has anyone rewired an obdI alternator and used it with an obdII? I read somewhere that 2 wires are the same and the other 2 are different. Does anyone know which wires match up with which?
fyi: there are 4 wires on mine. A white, white/green, black/yellow, and white/blue.
Old Jan 9, 2003 | 11:05 AM
misledyouth's Avatar
New User
Default Re: alternator obdI to obdII (asianspeed)
i have there are two wires that are the same and the two that are diffrent colors.
obd1 :: the bottom left and the top right are the same but then just match t
obd2 :: the other two up and it should work fine. kinda hard for me to explain but if you keep the wires looking the same aka 2 corners will match then just put the other two corners together.
if that makes any sense haha soorry
jesse
Old Jan 9, 2003 | 11:28 AM
asianspeed's Avatar
Default Re: alternator obdI to obdII (misledyouth)
Hehe...ok, I didn't get that. What do you mean by, "you keep the wires looking the same aka 2 corners will match then just put the other two corners together."?
Old Jan 19, 2003 | 07:31 PM
salt's Avatar
OK I need to know this too. I have a OBDI wiring harness and an OBDII alternator and pigtail. Judgeing by the other post this seems to be the correct way:
OBDI |OBDII
black+ yellow | black+ yellow
white + blue | white + blue
blue |white + red
white + yellow |white + green
does anyone know if this is correct ?
[Modified by salt, 9:24 PM 1/20/2003]
Old Jan 20, 2003 | 05:24 PM
salt's Avatar
Default Re: alternator obdI to obdII (salt)
If no on knows I'm going to try this, it seem right. If you hold the plug the same way two of the wires match up. The other two are different, but I assume they were going to the same place. I dont think honda would switch them, but you know happens when you assume...
Old Mar 14, 2003 | 04:02 PM
salt's Avatar
ok I tried this and it worked, so just for the archives, the above wiring is correct!
Steve
Old Jul 29, 2003 | 01:45 PM
owen_the_soyboy's Avatar
thanks SALT you saved me from hours of B.S.
HondaTech archives rule
Old Aug 3, 2003 | 03:42 AM
drevinder's Avatar
i just used my ob2 alt. with the obd 1 motor
just put washers in the alt. mount and extend it works fine for me i wish i had a pic to show u but if u want it i will try to get it to u
Alex Preece
Oct 3, 2018 07:36 PM
white4doorsi
Apr 28, 2008 10:12 AM
ek_chris
Sep 5, 2006 07:09 PM
