all motor or turbo
Old Feb 3, 2003 | 06:18 AM
b16 pwrd ek's Avatar
Default all motor or turbo
I have a jdm b16a2 in my 96 cx. I have converted it to obdI and i just want to know should i go all motor (ls/vtec) or should i turbo my b16
__________
9.2@76mph 1/8th
intake
2.5" exhaust
Old Feb 3, 2003 | 07:09 AM
evolve's Avatar
Default Re: all motor or turbo (b16 pwrd ek)
I'd stick with the full B16A and go to higher revs. An all motor mildly modded B16A(with stripped interior) should get you in the 14's easily.
[Modified by evolve, 4:10 PM 2/3/2003]
Old Feb 3, 2003 | 10:03 AM
Flexmyrex's Avatar
Default Re: all motor or turbo (evolve)
boost
just my 2 cents
[Modified by flexmyREX, 7:04 PM 2/3/2003]
Old Feb 3, 2003 | 11:04 AM
SteveeeO's Avatar
Default Re: all motor or turbo (flexmyREX)
boost it, from what many people say lsvtec is very unreliable ... it sounds like your daily driver, so why make ur car all nasty and strip the interior? what a waste for .2 seconds
Old Feb 3, 2003 | 03:25 PM
joe_bocc's Avatar
Default Re: all motor or turbo (SteveeeO)
boost the hell out of it!!!!
Old Feb 3, 2003 | 04:43 PM
junb16's Avatar
go NA but keep the full b16 motor and rev high like the other guy says. all motor is the way to do it
Old Feb 3, 2003 | 04:57 PM
lazy bum shaughn's Avatar
Default Re: all motor or turbo (junb16)
Man whatever, it takes too much money to make all motor fast. Just turbo that ho.
Old Feb 3, 2003 | 05:03 PM
turbodsmpower's Avatar
whats the hatred on the lsvtec is a very powerful combo when done right. I love boost just to much hassle to deal w/. Build a nice LS vtec go all motor. you be proud once youve beaten a few turbo cars w/ just the motor. B16 is just to small of displacment.
Old Feb 3, 2003 | 06:52 PM
1 2 NV's Avatar
depends what u want to do. personally im an all motor guy. NA cars absolutely rule the streets then some guys add NOS to the equation and really rule.
theres problems with any setup whether its NA or turbo. realistically just bolting on a turbo is ok, but it still puts a car like urs into the mid 13s, tuned correctly on low boost it should run lower 13s maybe high 12s. problem with turbos is they are hard to launch because they put out alot of torque.
NA on the other hand is expensive yet once built correctly they dont have traction issues cause they dont put out near the torque. roughly for a decent cam setup (skunk2 stage 2s) ur lookin at 1700 which isnt too bad. really if u pick and choose ur NA parts correctly it should cost about the same as a basic "bolt on" turbo kit. i say go NA cause on the street they rule, at the track they still rule. bottom of the line is that most turbo cars arent fully built nor tuned.
Old Feb 3, 2003 | 07:06 PM
D16Z6racing's Avatar
Default Re: all motor or turbo (lazy bum shaughn)
Really?
Lets see, good to great turbo kit with everything needed is $2600-$5000.
High quality motor build with everything needed is $2500-$4000.
1) A lot of people say they'd spend $4000 for a GSR swap. While with $4000 I can build my SOHC VTEC to be faster than the GSR.
2) Then the next $3000-$4000 for the GSR guy goes for a motor build for turbo, while the SOHC VTEC that is already built, just got a APEXi turbo kit with everything needed.
3) The next high bundle of money for Mr. built/GSR goes for his turbo kit. Then Mr. built/SOHC/turbo spend not <U>nearly</U> that high amount for, lets say a 55-65 shot of juice.
No matter how you look at it, it just seems a motor build is cheaper and will benifit you in the long run. IMO. And I'm stayin' SOHC, so even better for me.
Just IMO.
Old Feb 3, 2003 | 07:21 PM
civicbro's Avatar
BOOOSTT that babbyyyy!!!!!
Old Feb 4, 2003 | 04:58 AM
thanks for all your opinions
all will be put in consideration just depends on how much i get back in taxes
streetking898
Jan 24, 2007 08:50 PM
shibikku95
23
Jun 30, 2006 06:00 PM
400hpJDMSI
11
Aug 3, 2005 06:37 PM
h22a193
18
Oct 7, 2003 10:34 AM
ITR1071
May 20, 2002 10:01 AM
