are all bseries clutches the same?
Old Sep 11, 2006 | 05:18 AM
Black R's Avatar
25 Year Member
Default are all bseries clutches the same?
what are the differences between, say a 92gsr cable tranny clutch and a 2000 itr hydro clutch? etc?
Is the difference just in the pressure plate or just the clutch disc itself?
Old Sep 11, 2006 | 06:53 AM
Azn Kenny's Avatar
The clutch, fw, and pressure plate are interchangable if both trannys are hydro.
But not hydro and cable trannys.
Old Sep 11, 2006 | 12:28 PM
unknown0001's Avatar
Default Re: (Azn Kenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">The clutch, fw, and pressure plate are interchangable if both trannys are hydro.
But not hydro and cable trannys.</TD></TR></TABLE>
Wrong on the flywheel part.
Flywheels are interchangable between hydro and cable tranny's...but not clutch and pressure plate.
So you can use a flywheel from a 91 integra(cable) on a 98 ITR(hydro)
Old Sep 11, 2006 | 12:42 PM
NIKE SB'd's Avatar
Default Re: (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Wrong on the flywheel part.
So you can use a flywheel from a 91 integra(cable) on a 98 ITR(hydro)</TD></TR></TABLE>
Are you positive on that one? Because I have personally taken an entire clutch assembly off a OBD0 B16A w/ Y1 cable tranny (was converted to hydro though) and installed it into a 96 B18C type R w/ USDM S80 ITR tranny and it worked fine.
Old Sep 11, 2006 | 01:00 PM
Default Re: (NIKE SB'd)
Are you positive on that one? Because I have personally taken an entire clutch assembly off a OBD0 B16A w/ Y1 cable tranny (was converted to hydro though) and installed it into a 96 B18C type R w/ USDM S80 ITR tranny and it worked fine. </TD></TR></TABLE>
Do a search on here...'supposedly' using a cable clutch/pressure plate wont work on a hydro transmission...I personally don't see why not but I'm going by what I was informed and some of the different part numbers for clutch kits between hydro and cable transmissions.
Old Sep 11, 2006 | 02:02 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Input shaft sizes are larger on ITR transmissions, so the pilot bearing will not be the same.
Old Sep 11, 2006 | 03:57 PM
anthony90si's Avatar
i believe that flywheel and pressure plate are the same. 90-91 do not have the same splines as 92+ so the discs are not the same
Old Sep 11, 2006 | 06:50 PM
Runnerdown's Avatar
Default Re: (anthony90si)
Here are some facts to help this thread:
all b-series pressure plates and flywheels are interchangable.
all 1992 and up transmissions share the same disc, and input shaft. YS1, Y21 S4C S80 etc.. yes this does cover 2 years of cable trannys.
1990-1991 integra and all jdm Y1, J1 S1 share the same clutch disc and input shaft.
Old Sep 11, 2006 | 07:08 PM
Default Re: (Runnerdown)
also to add
90-91= small spline
92-01= bigger spline
92-93 and 94-01 clutches are the same app. regardless if its cable or hydro
Old Sep 12, 2006 | 04:30 AM
Black R's Avatar
25 Year Member
so i could use a big-spline clutch disc and mate it with a bseries cable tranny pressure plate; and bolt that whole assembly to a 2000 itr hydro tranny?
Old Sep 12, 2006 | 05:59 AM
Runnerdown's Avatar
Default Re: (Black R)
yes, its all the same stuff
Old Sep 12, 2006 | 09:45 AM
NIKE SB'd's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Input shaft sizes are larger on ITR transmissions, so the pilot bearing will not be the same. </TD></TR></TABLE>
This is true, I did have to change my pilot bearing. Forgot to mention that. But as far as the main 3 clutch components I used everything.
Old Sep 12, 2006 | 10:48 AM
Natural Aspirations's Avatar
The throw out bearing is what makes the kits different, that is teh ONLY difference
SlowSlammedSedan
Dec 2, 2005 02:59 PM
lilxvtecxpwr
Feb 11, 2005 11:47 AM
