alignment help
Old Nov 23, 2001 | 07:15 AM
89sir-9's Avatar
New User
Default alignment help
recently installed a set of ingalls camber kit (front kit) for my civic. my problem is that now my right front tire is off. making my tire squeal while im driving straight. how can i adjust this myself
Old Nov 23, 2001 | 09:05 AM
Crazydave's Avatar
Default Re: alignment help (89sir-9)
Point your wheel straight
find the tie rods, loosen the jam nut.. and turn the tie rod to make it longer or shorter to turn your wheel in or out.
the way to tell which way to turn it is to take a long string.. or extension cord or something, have a friend hold it across the middle of the back tire.. and hold the string against the middle of the front tire..
gap in the front of front tire .........turn out
gap in the rear of the front tire ....turn in
or for $30 take it to an alignment shop for a front end alignment
|<----string
| ___
||...T..|
||...I...|--------------
||...R..|
|.\_E_/--==tierod==
| ___
| \___/
or you could grease your tires
speaking of grease.. did you lube the bushings? and ball joints?
[Modified by Crazydave, 6:07 PM 11/23/2001]
[Modified by Crazydave, 6:10 PM 11/23/2001]
4ndreas
Suspension & Brakes
Jun 13, 2015 04:12 AM
agiorlando
Sep 14, 2008 04:44 PM
lke2drvgsr
Dec 19, 2003 12:14 PM
MrIllegalX
Oct 18, 2003 11:45 AM
89sir-9
Dec 14, 2001 01:44 PM
