air/fuel gauge problem
Old Feb 10, 2005 | 07:03 PM
btrim23's Avatar
Default air/fuel gauge problem
Recently install the wiring of my air/fuel gauge. This install is on a 93 prelude si, all three wires were, hopefully connected the right way. Black ground, Red power from source that turns it on, and Violet to one of the wires from the O2 sensor. When all the wires connect up, my gauge show and idles at lean *3 red l.e.d instead of bouncing back and fort between the mixture or when driving. Please advise on what could be wrong. ex: o2 sensor, wiring, or it's actual true reading from the gauge. thank you.
Old Feb 10, 2005 | 10:03 PM
PrettyLude's Avatar
bad o2 sensor?
Old Feb 11, 2005 | 12:23 PM
btrim23's Avatar
wouldn't it throw a code if your o2 sensor is out? (Check Engine)....
Old Feb 11, 2005 | 03:32 PM
vtekstorm's Avatar
Default Re: (btrim23)
the purple wire gets connected to the white wire on the o2 and check yoru wire connections .
Old Feb 11, 2005 | 08:01 PM
btrim23's Avatar
well, thanks. I think I have the purple wire connected to one of the black wires thats why it blinks constant on Lean mix. From what I remember, there is a white, green, and 2 black wires from the o2 sensor. So it must be the white?
Old Feb 11, 2005 | 09:36 PM
PrettyLude's Avatar
yea purple goes to the white
Project_DX
Dec 16, 2005 08:14 AM
powerneedy
Mar 2, 2005 03:13 PM
DLB1994
Dec 13, 2003 07:25 PM
2.0L EK
Dec 2, 2002 07:18 PM
Cyber ITR
Jan 28, 2002 08:03 PM
