Air conditioning compressor belt squeals when tight? A/C problem
Old Apr 8, 2011 | 07:27 AM
eastbay92cx's Avatar
Default Air conditioning compressor belt squeals when tight? A/C problem
1988 Civic DX D15B2 engine. The car's A/C compressor was frozen (would not turn at all), so I evacuated the refrigerant and replaced the compressor with a used unit. After refilling the refrigerant and oil using a low side pressure gauge, the air conditioning was functional for 1-2 days. The belt then started squealing once the compressor was turned on for 1-2 minutes. The belt was adjusted properly. The problem seems to be that the compressor becomes too difficult to turn after operating for a short time. Has anyone experienced this? What might be the problem?
Old Apr 8, 2011 | 06:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Air conditioning compressor belt squeals when tight? A/C problem
You have an obstruction I would guess head pressure is going through the roof, well over 300PSI.
My guess is the expantion valve... http://www.redlinemotive.com/store/r...xpansion+Valve is plugged up, possibly the filter/dryer also.
When a compressor goes west, the filter dryer should always be replaced along with the compressor, but my guess is "chunks" from the compressor have plugged the expantion valve. 94
Old Apr 8, 2011 | 06:33 PM
I remember reading that. Thank you for the reply.
eastbay92cx
Apr 8, 2011 04:28 PM
Hollowheart
Jun 10, 2010 02:10 PM
itzyaboyzeem03
Jul 27, 2009 12:02 PM
rubens
Sep 4, 2003 08:23 AM
