a/c compressor problem
Old Jul 25, 2009 | 03:05 AM
itzyaboyzeem03's Avatar
Post a/c compressor problem
my ac stopped blowing cold and i already checked the freon and everything, i noticed that the ac compressor doesnt spin....well the belt spins, but it seems like the opposite side slipped off or something cuz theres a pretty big gap and i can manually spin it while the belt is spinning, how do i fix this???
Old Jul 27, 2009 | 10:48 AM
ahcapone's Avatar
Default Re: a/c compressor problem
Your clutch is not being pulled in.
Old Jul 27, 2009 | 12:02 PM
all-mtr-teg's Avatar
The freon may be too low, therefore the low pressure switch is not allowing the a/c clutch to engage. Take it to a shop that is competent in a/c servicing. They will pull a vacuum on the systema and remove any moisture in the system, replenish the oil if its low, and charge it according to specs.
Assuming nothing is wrong mechanically.
SIR 1.6
Aug 1, 2012 05:23 AM
powerlineDC2
May 25, 2010 05:18 PM
092eg6
Jul 25, 2009 11:56 AM
jamesjarvis85
Sep 12, 2007 01:04 PM
veggiemaster
Jul 17, 2005 08:46 PM
