Aem Cam Gears,timing problem.
Old Nov 28, 2006 | 06:25 PM
teamitr's Avatar
Default Aem Cam Gears,timing problem.
I just put back together a b16 motor and when i was doing the timing i use the pins to lock the cams in place but i notice that the marks on the aem adjustable cam gears were at 3 aclock not straight up. and also the guides for the pins to hold the cams in place are to the side right? not straight up like the b18 engine.
so i went ahed and turned the engine over but i did not want to start, I did a compression check and the gauge. berely moved up like to 10 or 15psi so i was wondering what i should do with the timing marks should i place them straight up.
or is something else wrong?
IMHARD2
Jan 24, 2009 11:18 AM
StreetRac3r
Jun 7, 2007 09:12 AM
kennymr22
Jan 3, 2005 09:09 PM
chet
May 15, 2004 01:14 PM
riceballz2001
Jun 15, 2002 04:59 PM
