Adjusting Valves
Old Oct 11, 2005 | 09:46 AM
doublejz's Avatar
Default Adjusting Valves
Ok so i just read a post that says when adjusting valves you can do a trick and do the following.
With #1 at TDC, adjust both intake and exhaust on 1, intake on 2, exhaust on 3.
Adjust to #4 at TDC, adjust both intake and exhaust on 4, intake on 3, exhaust on 2.
Will this work? I always thought you had to do 1# cylinder, rotate 90 degrees and #2 and so on??
Old Oct 11, 2005 | 11:14 AM
doublejz's Avatar
Default Re: Adjusting Valves (doublejz)
anyone?
Old Oct 11, 2005 | 02:06 PM
gents97civ's Avatar
I always just start at number one and turn the engine over till they are loose. Its pretty easy to tell. You can check with a screwdriver down the sparkplug hole to see that its tdc
Old Oct 11, 2005 | 04:14 PM
drdisco69's Avatar
That trick (or something like it, I don't remember the order) is right, but I never used it. It takes a whopping 20 minutes to adjust valves the normal way, and the chance of forgetting which ones you've adjusted and which ones you haven't is greater.
Old Oct 11, 2005 | 04:32 PM
NJIN BUILDR's Avatar
Default Re: Adjusting Valves (drdisco69)
Adjust the intakes as the exhausts starts to open.Adjust the exhausts after the intakes reach full lift and start to close.
Glenn
Old Oct 12, 2005 | 05:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">Will this work? I always thought you had to do 1# cylinder, rotate 90 degrees and #2 and so on??</TD></TR></TABLE>Yeah, I've never found it to be very difficult to turn the engine 90 degrees for each cylinder... That trick would probably only save me about 60 seconds on a valve adjustment job.
Old Oct 24, 2005 | 01:45 PM
gents97civ's Avatar
how did it go?
Old Oct 24, 2005 | 02:10 PM
doublejz's Avatar
Default Re: (gents97civ)
didn't get to it yet, had to order cam cap bolts....
sup3rd
Nov 26, 2007 06:30 PM
breathinez
Aug 24, 2004 10:35 AM
senpai
Jul 25, 2003 07:49 AM
P1mpSlap
Apr 21, 2003 12:36 AM
vwandhondaboy
Sep 29, 2002 12:08 PM
