ACT clutch, disk rattling?
Old Jul 16, 2002 | 01:18 AM
MikeSarr_GSR's Avatar
Default ACT clutch, disk rattling?
hey guys,
who has experienced this>? my clutch disk rattles when the car idles
under 800rpm kinda like a clackaclackaclackaclacka. when I push in the
clutch it stops, when I release it continues. what is the cause of this?
This issue is intermittant, it comes and goes. Lately, more than usual.
I increased my tuning and made some more TQ... then I began to
notice it. It used to only do it when the AC compressor clutch was
engaged.
I have 13K+ miles on the clutch now HD/SS kit with an OEM ITR flywheel
in my GSR.
Any insight would be helpful!
Old Jul 16, 2002 | 05:40 PM
BreakStuff's Avatar
New User
Default Re: ACT clutch, disk rattling? (MikeSarr_GSR)
That chatter you are hearing is the resonating/vibration of the clutch disc springs, common in aftermarket clutch kits, the first line of S2000's also had this condition and an updated disc was issued to remedy the noise.. my personal car has been doing it for years without any problems..
Old Jul 16, 2002 | 06:38 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
is it a rapid rattling or sort of chirping? mine does a rapid chirping (annoying as hell) only at low rpms and goes away when i clutch a few inches. i am pretty sure mine's just the release bearing.
not only am i getting that annoying noise, but i am getting a squeel/howl from either under the valve cover/timing belt side and i think it's either the water pump or the cam/journal. it's a lsvtec and i'm sure it's getting oil...i remember you had a problem with your cam journals. did it make a weird noise when the motor was idling? i am going to check the journals out but was just wondering about a strange noise if it made one. thanks mike.
Old Jul 16, 2002 | 07:00 PM
BreakStuff's Avatar
New User
Default Re: ACT clutch, disk rattling? (not so civic)
That brings back some memories NSC, I used to remedy chirping release bearings by pulling back the rubber boot by the slave cylinder and spaying lube within the vicinity of the bearing, amazing what a little grease in the right spots can fix..
and on another note, if you hear a high pitch squeek type noise it usually a component being dried out and not getting sufficient lube.. i wouldn't suspect a bad cam journal here.. a good tip would be to get a long screwdriver or pry bar and stick one end on your ear and the other end where you suspect the noise to be, concentrate on the waterpump, alternator, PS pump,etc, the noise will be considerably louder where the problem is and will be easy to diagnose..
Old Jul 16, 2002 | 07:10 PM
Default Re: ACT clutch, disk rattling? (BreakStuff)
thanks breaker...those are the kind of tips i can use. so what should i spray for lube? i thought about greasing with some kind of extension onto the bearing but spraying the thing would probably be easiest.
Old Jul 16, 2002 | 07:56 PM
I think I will call ACT and bitch so I can get a 6puck... hehe
Old Jul 16, 2002 | 08:16 PM
BreakStuff's Avatar
New User
I used to use the OEM Honda white lithium grease with the little straw attached to the nozzle.. I remember bending the end of the straw to give me the right spraying angle to complete my task.. : )
Old Jul 16, 2002 | 08:34 PM
UNVMYR's Avatar
Its gotta be the trow out bearing,I 2 have a ACt with the same problem ss/hd with itr flywheel,(helicopter) is what comes to mind when i hear that noise.From what I understand, is if it goes on for a period of time it can take effect on the trany.It also seems as if ACt has terrible relese bearings...HTH
Old Jul 16, 2002 | 11:57 PM
sparkz's Avatar
hey guys,
engaged.
in my GSR.
maybe perhaps one of the springs inside is loose?
Old Jul 17, 2002 | 12:20 AM
Default Re: ACT clutch, disk rattling? (sparkz)
hmm... sounds like I should get on the ball with this...
at least I know the perfect candidate for the job
if in fact it needs to come out... MY FIRST CLUTCH
JOB!! yea. yea man, I will have the flywheel taken
off, get it machined and maybe see if I can get that
6 puck disk... and use a honda release bearing
more when I find out what the deal is. My boy Chris'
ITR with an ACT also sounds the same. I have a buddy
Joe who road races had the HD/SS and blew a spring
on a downshift (to high too soon) and ACT replaced the
disk free of charge to a 6 puck! Nadaproblemadude...
thanks for all yall chiming in, its very helpful
[Modified by MikeSarr_GSR, 9:20 AM 7/17/2002]
Old Jul 17, 2002 | 12:29 AM
SIK IN DA HED's Avatar
New User
seems normal to me. but it does get annoying and sometime i wonder if theres something wrong with it.
Old Jul 17, 2002 | 06:41 AM
nice! i'm off to acura to pay my friend a visit . thanks again.
DC5KING
42
Feb 22, 2017 08:31 AM
lswantsvtec
Jun 25, 2007 09:37 PM
Jmumblez2001
Aug 8, 2006 12:05 PM
BABY NSX
Jul 12, 2006 12:03 PM
Aphrodavid
12
Oct 14, 2002 04:26 AM
