ACL clearance??
Old Feb 9, 2004 | 06:17 PM
TurBoTeG's Avatar
Default ACL clearance??
Well i just plastigauged my Mains two times and i came up with the same results...im pretty much getting a .020inch across the board with the exception to journal #4 im getting .017inch or so. Is .020inch way to loose to even think about using? i do realize it is at the service limit...thanks guys!
Old Feb 10, 2004 | 01:15 AM
TurBoTeG's Avatar
Default Re: ACL clearance?? (TurBoTeG)
up
Old Feb 10, 2004 | 07:14 AM
maddog20's Avatar
Hmm? I'd say if you are in the service limit you are OK. But is this car a daily driver? I'd IM Earl or Rocket. They'd have better advice. But you need to tell them what the car is intended for.
Old Feb 10, 2004 | 08:14 AM
mmuller's Avatar
Mad Scientist
.020 is a little loose, but if you gonna turbo it should be ok.
Also you could keep the #3 and #4 as it is and get honda bearings for the rest to match the .017 from #4.
Acl's are green/brown
swizz977
Jan 3, 2014 03:02 AM
Datunnerkid
Feb 2, 2011 04:40 PM
.BigSexy
Feb 10, 2007 10:46 AM
Dyzee
18
May 14, 2004 10:49 AM
leadfoot78
May 9, 2004 09:51 AM
