ACL Bearings
Old Aug 10, 2007 | 06:45 AM
  #26
mahatma's Avatar
Default Re: ACL Bearings (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">do you have any supporting evidence on hand??</TD></TR></TABLE>
nope just remember that from researching.....but just because it was spouted here on h-t doesn't necessarily make it fact.
to me for spreading hearsay
for actually chopping one up to find out
Old Aug 10, 2007 | 03:37 PM
  #27
Reed's Avatar
Default Re: ACL Bearings (mahatma)
no to acl.
oem for life!
yay for being able to clearance to spec through bearing size, and not machine work.
Old Aug 10, 2007 | 04:02 PM
  #28
b18bEKcoupe's Avatar
Default Re: ACL Bearings (Reed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reed &raquo;</TD></TR><TR><TD CLASS="quote">no to acl.
oem for life!
yay for being able to clearance to spec through bearing size, and not machine work.</TD></TR></TABLE>
My helms manual seems to give me a range of allowable clearances. I was wondering if you knew what the "spec" clearance you speak of is?
Can anyone tell me the actual size difference between each color bearing is? I honestly don't know.
To be honest i very rarely have any bearing be out of the allowable range in the Helms manual. That doesn't always mean i use any bearing but at the same time the clearance i shoot for isnt the same for every motor. Are you saying that the clearance honda chose for its stock 150 hp motor is the same clearance you should be using for a motor that makes much more than that?
The reason most of us are on this forum is to modify and increase the power of our engines. We replace the pistons, change piston to wall clearances, ring gap, and add all sorts of aftermarket products. Many changes are made and non-honda parts are fitted. I dont see running an aftermarket bearing that give me the clearance i need to be a problem.
Old Aug 10, 2007 | 11:50 PM
  #29
BILLETGRIP's Avatar
Default Re: ACL Bearings (b18bEKcoupe)
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
Old Aug 11, 2007 | 12:10 AM
  #30
Legion's Avatar
* B A N N E D *
Default Re: ACL Bearings (BILLETGRIP)
I can't believe how stupid this thread is
People build motors every day with ACL bearings. They don't get any machine work done. They don't use OEM bearings. Everything ends up in spec, and the motors run fine.
I know some of you would like to show everyone else how much e-knowledge you have, but please, keep it to yourself. Some of us actually build motors and fast cars instead of spending all day becoming e-mechanics and bench racing.
Old Aug 11, 2007 | 03:31 AM
  #31
methos713's Avatar
Default Re: ACL Bearings (Legion)
acl vs oem debate...all over again.
Old Aug 11, 2007 | 11:10 AM
  #32
Chiovnidca's Avatar
Has anyone considered mixing acl with honda bearings? Say an acl race bearing on the upper side of the rods to take the abuse of the combustion, and honda in the cap to allow easy fine tuning of the clearance.
Old Aug 11, 2007 | 10:01 PM
  #33
Legion's Avatar
* B A N N E D *
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone considered mixing acl with honda bearings? Say an acl race bearing on the upper side of the rods to take the abuse of the combustion, and honda in the cap to allow easy fine tuning of the clearance.</TD></TR></TABLE>
You can't change the size of only the bottom bearing. The bearings have to be the same thickness as a pair or they won't match up where they meet.
Old Aug 11, 2007 | 10:40 PM
  #34
BILLETGRIP's Avatar
Default Re: (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">
You can't change the size of only the bottom bearing. The bearings have to be the same thickness as a pair or they won't match up where they meet.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=715490 &lt;---------you should read this
Old Aug 12, 2007 | 01:29 AM
  #35
Legion's Avatar
* B A N N E D *
Default Re: (BILLETGRIP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=715490 &lt;---------you should read this</TD></TR></TABLE>
Hmm. I guess it's possible. I personally would never do it. If Earl felt comfortable jumping a size, that's his thing. I know I wouldn't want a .0001"x2 out-of-roundness on any of my caps. I'd rather keep the sizes paired up and have less ideal clearances.
Old Aug 12, 2007 | 10:48 PM
  #36
BILLETGRIP's Avatar
jumping sizes would actually push your crank out of centerline if you jumped to far. but i dont think .0001 is gonna hurt anything with .0015 clearance.
Old Aug 14, 2007 | 05:54 AM
  #37
pomansouth01's Avatar
Ginger Kid
if you look at the thickness of the bearings on the chart posted above....jumping from one size to another may be the exact same size bearing...
Old Aug 14, 2007 | 02:28 PM
  #38
Chiovnidca's Avatar
Default Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">if you look at the thickness of the bearings on the chart posted above....jumping from one size to another may be the exact same size bearing...</TD></TR></TABLE>
ACL bearings are the same way. I had to shuffle em around till the clearances on all the bearings were about the same. Didn't mix in any honda bearings.
hmtcrxsir
Jun 7, 2009 01:42 AM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
bamboosted
Mar 17, 2005 09:24 PM
VtecKiDD
Mar 5, 2004 05:40 AM
