Accord won't start
Old Nov 16, 2004 | 01:43 PM
fst fox's Avatar
Default Accord won't start
I have an 88 accord 4cyl, bought it about a month ago, Fri when the cold snap came it won't start I have replaced plugs wires, cap rotor, I am playing with the timing but it just turns over then when it seems it's going to start it backfires through the carb? Yes I am getting fuel and also fire into the cylinders, those 2 elements should atleast make it start, I am at a lose right now and need help
Old Nov 16, 2004 | 03:23 PM
ogabudiah's Avatar
Default Re: Accord won't start (fst fox)
Try starting fluid and maybe advance the dizzy.
Old Nov 17, 2004 | 01:14 AM
fst fox's Avatar
already tried the starting fluid will try playing with the distributor in the morning had to buy a battery charger to charge the battery cause I wore it down
Old Nov 17, 2004 | 10:17 AM
justink4's Avatar
dont waste your time with the distributor its probably just your main relay
Old Nov 17, 2004 | 10:58 AM
fst fox's Avatar
Default Re: Accord won't start (justink4)
just found out it's a tec distributor and the part that is broke is a vacum advance now just to find a parts house that has it in stock.
Old Nov 17, 2004 | 07:02 PM
fst fox's Avatar
Okay replaced the vacum advance and still no start, I have fuel, fire, pulled the plug and no water mix so good head gasket, ? any ideas?
vaderman_x
Jun 9, 2019 07:00 AM
thasickness
Nov 30, 2014 02:23 AM
Bienval23
Aug 18, 2014 12:14 PM
samvilay
Oct 31, 2009 02:46 PM
