AC fan question - can it be replaced with something smaller?
Old Aug 15, 2005 | 06:51 PM
B18EG6's Avatar
Default AC fan question - can it be replaced with something smaller?
Just as the question states - I need a little more room in my bay for the turbo, can I replace this huge fan with something smaller? I Took it out today to look at it but I couldnt seperate the fan from the radiator itself.
Anything ?
Old Aug 15, 2005 | 08:35 PM
saxman's Avatar
Default Re: AC fan question - can it be replaced with something smaller? (B18EG6)
the fan does come off(I've done it... just takes a bit of work)... don't see why a different fan couldn't be used... I've been running around without a fan on for a few weeks now. a/c only works when I'm moving though... kinda amusing
Old Aug 15, 2005 | 11:23 PM
mtber's Avatar
flexalite fans are your friend... so is google.com :-)
Old Aug 16, 2005 | 08:05 AM
B18EG6's Avatar
Default Re: AC fan question - can it be replaced with something smaller? (saxman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxman &raquo;</TD></TR><TR><TD CLASS="quote">the fan does come off(I've done it... just takes a bit of work)... don't see why a different fan couldn't be used... I've been running around without a fan on for a few weeks now. a/c only works when I'm moving though... kinda amusing</TD></TR></TABLE>
lol. How did you get if off? Kinda pull it up or what, bend the supports? how did the new one mount?
im never drinking again.
edit -
Here is a pic of the setup, maybe it will help explain... i dunno
Modified by B18EG6 at 5:53 PM 8/16/2005
Old Aug 23, 2005 | 10:41 PM
saxman's Avatar
I just removed the visible screws, and pulled it off... the a/c radiator is held on with zip ties as normally the fan has the mounts on it... just a temp solution until I take the time to figure something better out. I don't have a low profile fan on it as of yet... just running the radiator by itself at the moment
B18 Dc4
Apr 17, 2009 07:32 PM
b18b1turbo
Mar 9, 2007 12:21 PM
ROOROWNS
Jun 6, 2005 05:44 PM
rusteds2k
Feb 11, 2004 10:11 AM
976
Sep 9, 2001 08:22 PM
