is replacing main bearing necessary??
i am in the process of sleeving my h22
and just wanted to know if it is recommended to replace the main bearings...
with OEM or can i just reuse the old ones...
BTW, the projected goal is 350-400whp...
if that makes a difference...
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">You gotta buy the rod bearings, I haven't seen any rods that come with bearings. Check out ACL's line of main bearings if you don't want to spend too much money.</TD></TR></TABLE>
oem mains are only like 9 bucks each...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">
1- Do it right the first time</TD></TR></TABLE>
Replace the bearings. Check clearances. Most people have no problems with the ACLs size being in spec.
I only had a problem with one acl main bearing, the other 4 were fine. Also, the stock bearings are like 10 bucks each, for one half. There's a top and bottom to each crank journal (5) and then you need the top and bottom half for the rods (4).
