99 htch starting problems
Old Mar 21, 2005 | 11:10 AM
cerpher's Avatar
Default 99 htch starting problems
Hey all,
My 99 Honda has trouble starting in the hot afternoon or if my car has been driven for awhile. My 99 will stale any time it wants. Worse times is 30 key turns till car runs again.
My car start in cold weather or not driven a lot. Example start car to and from work no worries. Go some where for lunch and run errors it will not start back up.
Starter is fine - because my car is turning over 30 times after it stales
Battery is fine - test it with my multi meter 14.2V when idle
All in all my 99 is great. Just when I turn off the car I have trouble starting it.
Note:
My 99 gets wet inside when it rains. Not when is not moving i.e. washing. If it rains and I drive it. My wheel well has water and my floor board has water. In fact I put my finger in the carpet and its about 1/2 inch of water.
Thanks to all
JC
Old Mar 21, 2005 | 12:06 PM
H22A_NeThing's Avatar
Default Re: 99 htch starting problems (cerpher)
Do you have an AF gauge? You could be running very rich after running for awhile, so rich in fact it's too much fuel for your plugs to ignite. check your plugs for a black carbon deposit (it'll probably look wet). Also check your ignition system and make sure everything's firing properly.
Old Mar 21, 2005 | 12:12 PM
snatch's Avatar
The water issue is not good. It's possible that water is shorting out some electronics causing the issue, check your distributor cap also for wetness on the inside. Wouldn't hurt to check the plugs too, just to do it.
Any idea where the leak is coming from? That really isn't a good thing if you can touch the carpet and it's saturated with water.
Old Mar 21, 2005 | 01:32 PM
cerpher's Avatar
Default Re: 99 htch starting problems (H22A_NeThing)
thx, will give it a go
Old Mar 21, 2005 | 01:35 PM
cerpher's Avatar
Default Re: 99 htch starting problems (******)
ur rite, i hv 2 smell it
my bro friend had the same problem, he found leave blocking water drain areas
sum r windshield and hatch
i hv no idea, no leaves, will get bk 2 u
Old Mar 21, 2005 | 06:48 PM
PrettyLude's Avatar
sounds like you have a combination of a bad ignition switch and main relay
Old Mar 22, 2005 | 02:41 PM
cerpher's Avatar
Default Re: (PrettyLude)
it that costly, should I just buy a new engine and sway it out
Old Mar 22, 2005 | 02:42 PM
cerpher's Avatar
I do not have a AF and do not know about Honda.
I can just adjust the richness right?????
Old Mar 22, 2005 | 05:56 PM
PrettyLude's Avatar
main relay and ignition switch is pretty easy to replace
Old Apr 25, 2005 | 11:54 AM
cerpher's Avatar
Okay after going through all you have said, I found that I have a head gasket leak. Could this be the problem
Old Apr 26, 2005 | 06:54 AM
PrettyLude's Avatar
a bad headgasket will still let the car start
Daget24
Honda CR-V & Element
Dec 22, 2023 08:27 AM
ezra76
Nov 24, 2008 10:04 PM
