99-00 climate control wiring help!
Old May 9, 2010 | 07:41 PM
si vtec ftw's Avatar
Default 99-00 climate control wiring help!
i need to know which wire coming out of the climate control plugs is for the compressor switch. there are 2 plugs with around 10 wires in each.
there is a wire that should connect the compressor switch to ground when you hit the button that says AC on it. if i ground the wires for the compressor it comes on, but i need to know what wire will allow the switch control when it is grounded and when it is not.
if anyone knows or has a pinout for the climate control unit PLEASE help me out here!
bjgill333
May 27, 2013 07:57 AM
cazper51
Nov 22, 2010 02:38 PM
