98 Civic Surging / code P1509
Old Dec 7, 2015 | 12:28 PM
drewbru's Avatar
Default 98 Civic Surging / code P1509
I have a 98 Civic DX D16Y7.
The engine is surging when it is cold. Engine code P1509.
Once the engine is warm, you can shut it off and then turn it back on again and its fine. You can then let it sit for a couple hours and it is still fine.
It has been getting progressively worse. When it first started doing it, just restarting it usually worked. Now you have to let it warm up.
I have taken off the IAC and cleaned it well.
I have done my best to make sure the air is out of the coolant.
I have replaced the Coolant Temperature Sensor.
I figure if it was an electrical or vacuum issue, that it would be more consistent.
Thanks for any help.
Old Jan 11, 2016 | 09:34 AM
drewbru's Avatar
Default Re: 98 Civic Surging / code P1509
I replaced the IAC valve and it resolved the issue.
brshqushr
Jan 6, 2015 08:51 AM
zcmotor
Oct 6, 2013 06:38 PM
silookalike
Jan 30, 2008 05:49 AM
BudMan
Dec 16, 2004 06:03 PM
FL~EXV6
Oct 8, 2002 05:32 PM
