97 Ingegra broken ex cam bolt
Old Nov 30, 2008 | 06:16 PM
xtremecycle98's Avatar
Icon6 97 Ingegra broken ex cam bolt
I ovetorqued one of my exhaust cam bolts (the longer one) the way the bolt broke caused my drillbit to walk all over the inside of the hole preventing me from using an EZ-out. I got aggressive and bought a Heliocoil, followed all the directions( I have successfully used them in the past) Now I cannot get the bolt to tighten at ALL. Is there ANY way I can fix this without taking off the head? ( I dont want to have to replace the gasket if I can avoid it$$) Should I try a different size Heliocoil? Should I take it to a machine shop? I need help please...its my daily driver...believe it or not, im pretty mech. inclined(just a dumb... for overtorquing the bolt) Thanks
Old Dec 3, 2008 | 05:16 PM
blackeg's Avatar
this happened to me too. i feel your pain. how far down into the bolt hole did it break? deep enough to slightly drill and retap using a slightly larger size? the aluminum will drill out easy because its soft, so you wouldnt really need a drill press for it
B-serius
Aug 10, 2009 02:21 PM
sph33r
May 28, 2006 05:59 PM
dblkack
Mar 16, 2005 05:24 PM
The Destroyer
Feb 19, 2005 01:47 PM
1.8EG-T
Nov 29, 2001 07:34 PM
