97 GSR o2 obd2-obd1 question
Old Feb 20, 2006 | 03:39 PM
strongarm1731's Avatar
Default 97 GSR o2 obd2-obd1 question
97 gsr, originally obd2 with p72. I bought the obd1 conversion harness and am now running a p28 with a crome base map. Now im curious... Does the second o2 sensor get used? If i recall, most obd1 cars use 1 o2 sensor (pre cat) where the one im curious about is the post cat or in cat o2 sensor. Heres a pic if it helps...
As you can see, i have a straight pipe on there right now and am redoing my exhaust. Im hoping i can run open header for like 2 days without that o2 hooked up OR just disconnecting it! lemme know peeps!
Old Feb 20, 2006 | 06:24 PM
lobudgetr's Avatar
Default Re: 97 GSR o2 obd2-obd1 question (strongarm1731)
OBD 1 p28 should only run 1 O2 sensor
no2unenolife
Nov 15, 2006 10:36 PM
SlammedBlackGSR
Oct 14, 2006 06:57 PM
pizzamanprelude
Aug 2, 2006 03:26 PM
strongarm1731
Feb 26, 2006 12:25 PM
Laserjock
Apr 16, 2005 09:50 PM
