95 gsr block compatible w/ 2001 type r head?????
Old Apr 16, 2003 | 05:22 AM
mr jun's Avatar
Default 95 gsr block compatible w/ 2001 type r head?????
delete post
Modified by gsr_hatch at 9:47 PM 7/28/2003
Old Apr 16, 2003 | 06:24 AM
mr jun's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (gsr_hatch)
anyone?
Old Apr 16, 2003 | 06:28 AM
advanracing62's Avatar
yep it will work.
Old Apr 16, 2003 | 06:33 AM
mr jun's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (advanracing62)
thanks ...Is there anyone else that could elaborate more on my question though?
Old Apr 16, 2003 | 07:27 AM
mr jun's Avatar
bump
Old Apr 16, 2003 | 08:14 AM
VTEC-DA's Avatar
Yes, it will all bolt together and run properly.
Old Apr 16, 2003 | 02:59 PM
mr jun's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (VTEC-DA)
thanks for the imput anyone else?
Old Apr 16, 2003 | 04:04 PM
preludacris's Avatar
yoooo
Old Apr 16, 2003 | 05:14 PM
mr jun's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (preludacris)
haha wassup preludacris
Old Apr 16, 2003 | 05:35 PM
dwn-shift's Avatar
You should be fine everything will bolt up. As for the OBD you should be fine just hook up all the senors from the head to harness you are usning and you should be fine.
Old Apr 16, 2003 | 07:50 PM
NonovUrbizniz's Avatar
Loved
Default Re: 95 gsr block compatible w/ 2001 type r head????? (dwn-shift)
obd 1 v 2 is just the ecu diagnosis system... On Board Diagnosis..I vs II
the heads are mechanical parts... ALL b series parts can fit on ALL other b series blocks... vtec->non-vtec MAY require modification... but vtec->vtec is usually just a swap affair.
Old Apr 16, 2003 | 07:58 PM
sander's Avatar
2.7(p/t)
all you will need to know is that the injectors from the itr head will not work with the obd 1 engine harness and the ITR distrubtor will not work with the obd 1 engine harness. basically if you use your distrubtor and injectors from your OBD 1 gsr, it will work fine.
Old Apr 16, 2003 | 08:00 PM
acuratech's Avatar
In my opinion i would change out pistons to itr, jdm itr, or ctr. Your compression is not going to be all that high with the gsr pistons. Unless of course you are intending a FI on it. But as far as compatability, yes it will bolt on, and run.
Old Apr 16, 2003 | 08:10 PM
10K2HVN's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (acuratech)
JDM ITR or USDM B16 very fair compression...
Old Apr 16, 2003 | 09:15 PM
MikeSarr_GSR's Avatar
Default Re: 95 gsr block compatible w/ 2001 type r head????? (10K2HVN)
get a cheap *** B16 salvaged head and have the intake valve runners p/p
and tanked/exhaust vavles tested and cleaned
add ITR intake valves (lighter, less dish area, more flow)
ITR LMAs (for 11mm and up cams/high revs)
new exhaust valve guides and all new valve seals
Get an ITR intake manifold also.
OBD is determined by the letters...
on board diagnostics... it is ECU y0
Old Apr 17, 2003 | 05:02 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuratech &raquo;</TD></TR><TR><TD CLASS="quote">In my opinion i would change out pistons to itr, jdm itr, or ctr. Your compression is not going to be all that high with the gsr pistons. Unless of course you are intending a FI on it. But as far as compatability, yes it will bolt on, and run.</TD></TR></TABLE>
yep, that is correct. do considering on what piston are you plannin to used. as he mention, using the stock GSR piston will lower your compression. as a other memeber has mention, while you everything apart, spend the extra money of some nice internal work. this way, in the long run, you don't have to it all over again.
in10ceCiviC
Dec 17, 2006 12:59 PM
jdm_dc_fan
Apr 28, 2006 01:57 PM
JRDbuilt
Apr 30, 2005 11:19 AM
WildMan541
May 21, 2003 12:54 AM
ahcjar103
Dec 10, 2001 12:20 PM
