95 Civic Lug Nut Stud Replacement
Old Aug 11, 2010 | 11:11 AM
zeeartist09's Avatar
Default 95 Civic Lug Nut Stud Replacement
So i found one of my studs had broken off one day i looked at my wheel. So i did some research and decided to replace it. I got to the point where i had the brake caliper off and the rotor. But then when i started to hammer the broken stud out it hits the back of the hub. There is no clearance for it to be hammered out. My question is do i have to separate the hub to get it out and then place the new one in?
So angry on the design of this -_-
Old Aug 11, 2010 | 11:14 AM
d16y8turbo's Avatar
Default Re: 95 Civic Lug Nut Stud Replacement
If it's anything like the 96-00 civics then you need to pull the hub.
Old Aug 11, 2010 | 01:10 PM
How remove hub of front?
Old Aug 11, 2010 | 05:43 PM
d16y8turbo's Avatar
You need a hub puller or slide hammer...im not sure if they're the same thing, but i have a slide hammer. You just bolt it to 2 or 3 of the wheel studs and slide the hammer away from the hub and it comes right off.
I'm not sure if there is a way to do it without one of these tools...but i couldn't figure it out.
Old Aug 12, 2010 | 04:13 AM
kyden's Avatar
you have to pull the knuckle and press the hub out.
Old Aug 12, 2010 | 09:51 AM
A shop charges like 75-100 for the job because of labor.
And Cutting the dust shield doesnt do ****. So now i have to either borrow or buy a slide hammer
marvin75
Apr 24, 2011 05:48 AM
airikkCRX
Jan 16, 2010 04:31 PM
JJ's civic
Sep 29, 2006 05:01 PM
Eucalyptus lude
Apr 24, 2005 11:50 AM
turboD16
Apr 4, 2002 11:50 AM
