'94 civic del sol starting issues
Old Apr 30, 2013 | 05:31 PM
Brittanybraa's Avatar
Default '94 civic del sol starting issues
So I have a '94 del sol, 162k miles on it, manual trans, with a kill switch. Runs great on a normal basis and I drive it every day. Got in today, kill switch off, key in, foot on the clutch turn the key. Andd.. Nothing. Acc on everything working, except my engine isn't running. Turned the kill switch on and off, finally ended up disconnecting the whole thing and taking it out because of a disconnected wire. Engine still not running. So what's wrong with my car?
Old May 1, 2013 | 09:20 AM
Jimmy Wyrick's Avatar
Default Re: '94 civic del sol starting issues
check youre under hood fuse box for the 50amp i.g. fuse ,also check on youre starter that ther is a 1 wire conected to it does youre dash lights come on is youre battery charged .we need more info to help and you should research more. this typ of problem has been coverd manny times before
Old May 6, 2013 | 07:18 AM
50 amp fuse was blown, replaced yesterday. Radio comes on, cluster works, headlights on too. Car still doesn't start. Starter is fine, been tested, no other fuses blown, battery is good.
Old May 6, 2013 | 11:55 AM
SolScifen's Avatar
Is it cranking and not firing?
Have you checked there's fuel getting to the cylinders and that you have spark at the plugs?
Old May 7, 2013 | 05:17 AM
it is not cranking, and it blew the 50amp battery fuse under the hood.
Old May 7, 2013 | 10:19 AM
Former User's Avatar
Turn key off.
Install a new 50A fuse.
1) Turn key to ACC -- does the 50A fuse blow? If not:
2) Turn key to ON(II) -- does the 50A fuse blow? If not:
3) Turn key to ON(III) -- does the 50A fuse blow?
Post the key position that causes the fuse to blow.
Old May 8, 2013 | 07:54 AM
The fuse is good now, it hasn't blown since I replaced it. Don't know why it blew
Old May 8, 2013 | 08:05 AM
Do the tests I mentioned, if the fuse blows again.
Old May 8, 2013 | 03:27 PM
It didn't blow.
Old May 8, 2013 | 03:42 PM
Mikzize's Avatar
Does your battery have enough juice in it to crank over ?
Old May 8, 2013 | 05:50 PM
fcm's Avatar
fcm
Old Fart
https://honda-tech.com/forums/showth...cm+bypass+jump
Let me know what you find. 94
Old May 9, 2013 | 09:14 AM
Battery was good. Found the problem. There was a connector off that keeps grounding out and blowing fuses and there was a whole relay missing. Problem has been fixed and starts without a hitch
DaWingler
24
Aug 26, 2013 09:47 AM
kimbothegiant
May 28, 2013 11:56 AM
gnickolascarlin
Mar 11, 2013 04:17 PM
areed15
May 15, 2011 08:50 AM
