93 del sol engine died while driving need help
I drive a 1993 honda del sol it has a 1.6L soch engine and on friday the car was runing fine and before i even left the street where i live the engine suddenly died and it would not turn back on. Everything else worked just the engine would not start so i took the car to the a near by shop and they told me the o rings for the injectors were cracked and leaking. Then another of the guys that worked there told me that the injectors were not closing at all and that the fuel was just flowing to the pistons. Then they started saying it was the computer but if that was the case nothing would work right? there would be no fuel delivered at all or the engine wouldnt even try to start. i need some help on this im just trying to not get ripped off by the shop. thanks
try to barrow a friend computer first t check that... and you can take you own fuel rail off to check the injector orings. maybe see if a buddy around has a set of injectors you can try out too!.... my car as you can see my pst sorta did the same thing but i turned it off now it dont start but i got two computers so.. its not that....
i will let ya know what my problem is a little later when i get done trying things out
You should preform some tests so the people here have more info with which to diagnose your problem. You could check the grounds, fuel pressure, the spark at all four wires, the intake vacuum and/or the ignition and valve timing.
Bipolarcivic
30
Apr 10, 2016 07:26 PM
mikegyverone
Dec 2, 2013 09:11 AM
TunerFreak24
19
Nov 17, 2010 09:06 PM
jordo155
10
Jun 7, 2009 07:44 PM
