91 civic b16 swap FLASHING A 10 CODE NEED HELP
Old Aug 10, 2005 | 03:08 AM
kidrolla's Avatar
Default 91 civic b16 swap FLASHING A 10 CODE NEED HELP
ok i just put in a ukdm cluster and got everything wored up and checked my ecu to make sure no codes wel the was a 10 code. i dont think the cluster install is it cause its ben actin a lil odd lately.like the car seems to die for a second and then run fine. kinda seems like at a steady pace it will pull a lil bit and fall back a lil bit over and over. but a 10 is 10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor i didnt think the obdo ones have that but if they do can you tell me where its at
Old Aug 10, 2005 | 03:09 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 91 civic b16 swap FLASHING A 10 CODE NEED HELP (kidrolla)
If you have a B16, its the white two pin sensor on the intake manifold runner.
Old Aug 10, 2005 | 01:13 PM
kidrolla's Avatar
Default Re: 91 civic b16 swap FLASHING A 10 CODE NEED HELP (JDM_Ej)
yeah its on there and today on my home from work the car died and and is flasing a 10 and 17 code now and i think my main relay is going out.
Old Aug 10, 2005 | 07:33 PM
kidrolla's Avatar
cleansi
Engine Management and Tuning
13
Sep 28, 2011 10:10 AM
TRhatchCRAP
Aug 1, 2003 05:40 PM
FOrSfEd
May 29, 2002 01:40 PM
turboex
May 16, 2002 05:13 PM
