89crx d15b2 dizzy wire problems
Old Mar 17, 2012 | 08:41 AM
101crx's Avatar
Default 89crx d15b2 dizzy wire problems
I have a 89 crx si with a d15b2 with a pm6 ecu an a 92civic intake with the stock injectors that go with the intake, but the dizzy had the plug taken off the dizzy an the harness has wires ran directly from the ecu to the motor. I've got the motor to crank but it wont fire up an run. I have tried to search an wire up the dizzy from several different sites an im about to give up cause it gives me a headache everytime I think of the wiring. I need advice to try an solve this problem PLEASE!!! The good is the ignition, starter, main relay, plugs, wires, grounds, connections, fuses, ecu.. I cant think of anything else at the moment.. I really could use some help please!?!?!?!?
Old Mar 18, 2012 | 08:14 AM
101crx's Avatar
Default Re: 89crx d15b2 dizzy wire problems
I could use help as soon as possible please..
Old Mar 18, 2012 | 02:02 PM
civickiller's Avatar
match same distributor colored wires on the harness?
Old Mar 23, 2012 | 02:01 PM
101crx's Avatar
i wish it was that easy. the colors dont match up
Old Mar 23, 2012 | 03:49 PM
HondaPartsHero's Avatar
Technical Hero
Aside from using the factory service manual your best bet is to get a new engine harness and start over.
Old Mar 23, 2012 | 03:50 PM
Technical Hero
So you are using the OBD1 injectors? If so you'll need some OBD0 to go with that PM6.
Boost Junkie 83
Mar 18, 2011 09:35 PM
Tshoemaker
Dec 29, 2010 09:46 PM
phatboyzef2
23
Dec 15, 2010 05:29 PM
hybrid1990crx
Nov 21, 2004 09:14 AM
ICeDoUt
May 28, 2003 10:14 AM
