89crx d15b2 dizzy wire problems
I have a 89 crx si with a d15b2 with a pm6 ecu an a 92civic intake with the stock injectors that go with the intake, but the dizzy had the plug taken off the dizzy an the harness has wires ran directly from the ecu to the motor. I've got the motor to crank but it wont fire up an run. I have tried to search an wire up the dizzy from several different sites an im about to give up cause it gives me a headache everytime I think of the wiring. I need advice to try an solve this problem PLEASE!!! The good is the ignition, starter, main relay, plugs, wires, grounds, connections, fuses, ecu.. I cant think of anything else at the moment.. I really could use some help please!?!?!?!?
Tshoemaker
Dec 29, 2010 09:46 PM
