83mm bore
Old Mar 18, 2008 | 03:53 PM
superfast666's Avatar
Default 83mm bore
what r my options for stock pistons or close too please help
Old Mar 18, 2008 | 04:47 PM
ctr83's Avatar
Default Re: 83mm bore (superfast666)
so your block is 83mm??
Old Mar 18, 2008 | 06:25 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">what r my options for stock pistons or close too please help</TD></TR></TABLE>
None. Even off the shelf after market is a little limited.
Old Mar 19, 2008 | 05:39 AM
StorminMatt's Avatar
For B-series, 83mm is an oddball size. You don't start to see more options until 84mm.
Old Mar 19, 2008 | 01:29 PM
ctr83's Avatar
Default Re: 83mm bore (StorminMatt)
i have 83mm cp pistons
Old Mar 19, 2008 | 02:19 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default Re: 83mm bore (ctr83)
You can always order some RS machine pistons, i they have 83mm oem spec pistons, and the also come with the skirt coating as well.
boostedb20z
Oct 21, 2007 04:57 PM
ekVtecPower
Jun 27, 2006 11:18 AM
lemongreenhatch
Sep 29, 2004 09:13 AM
importboi22
Sep 28, 2003 08:50 AM
hotintegranights
May 13, 2003 11:50 AM
