68mm tb too big???????????
car want idle smooth even after adjusting tps....
set up:
gsr head 3 angle valve job
skunk2 manifold
68mm tb STR
ctr cams
b16 block w/ ctr pistons
b16 injectors
fuel pressure is at 43 psi
should i go back to itr tb?
what else can i do?
is the 68mm too big for my set up?
set up:
skunk2 manifold
68mm tb STR
ctr cams
b16 injectors
what else can i do?
that is incorrect infomation...
i was running a 70mm ericksracing one and had ZERO problems.
and had less compression then you. take your time, figure it out.
what about upgrading the injectors to the prelude 345cc? ...they are peak and hold, plus im running 88-91 si harness.
yes thats to big your not running a b20 so litter 64mm would be your best bet all your doing is losing power if you don't believe me take it to get dyno and y'll see
this problem has nothing to do with the TB
I got a 68mm TB and runs smooth sound like a fuel issue instead of a throttle response
but for the set up u got yeah I would go back to ITR TB
but there is still a problem there
b16a1civichb
May 6, 2003 07:27 AM
thats turbo sized
